查看: 919|回复: 2
[编程技巧] how to do this problem???
发表于 2011-2-23 22:27 | 显示全部楼层 |阅读模式
n=[0.035,0.020,0.015,0.030,0.022]';
>> S=[.001,0.0002,0.0010,0.0008,0.0003]';
>> B=[10,8,19,24,15]';
>> H=[2,1,1.5,3,2.5]';
>> table=n,S,B,H
table =
    0.0350
    0.0200
    0.0150
    0.0300
    0.0220
S =
  1.0e-003 *
    1.0000
    0.2000
    1.0000
    0.8000
    0.3000
B =
    19
H =
    2.0000
    1.0000
    1.5000
    3.0000
    2.5000
U=sqrt(S)/n(B*H/B+2*H)^2/3
??? Error using ==> mtimes
Inner matrix dimensions must agree.
whta is wrong with this equation?  you guys can type chinese.i use school's computer,i cantot type chinese.
发表于 2011-2-24 17:17 | 显示全部楼层
回复 1 # speed_cat_0 的帖子
既然是矩阵,那么就应该使用点运算,例如*应该为.*;/应该为./
发表于 2011-2-24 17:20 | 显示全部楼层
  1. >> n=[0.035,0.020,0.015,0.030,0.022]';
  2. S=[.001,0.0002,0.0010,0.0008,0.0003]';
  3. B=[10,8,19,24,15]';
  4. H=[2,1,1.5,3,2.5]';
  5. >> U=sqrt(S)/n(B*H/B+2*H)^2/3
  6. ??? Error using ==> mtimes
  7. Inner matrix dimensions must agree.
  8. >> U=sqrt(S)./n.*(B.*H./B+2.*H).^2/3
  9. U =
  10.    10.8421
  11.     2.1213
  12.    14.2302
  13.    25.4558
  14.    14.7618
See? done
GMT+8, 2024-9-30 13:15 , Processed in 0.075382 second(s), 19 queries , Gzip On.
