查看: 1824|回复: 1
如何实现轮子在轨道上滚动!
发表于 2006-4-7 14:57 | 显示全部楼层 |阅读模式
我做的东西 ,想模拟轮子在轨道上滚动,用Pilot 节点做,出现问题较多,<BR>一个是力不随节点移动,而且好像转动也实现不了,版主或那位高人有这样的例子,<BR>或有好的想法指点一下,在下郁闷很长时间了,谢谢<BR>QQ:154248326
发表于 2006-4-9 07:46 | 显示全部楼层
回复:(liqun)如何实现轮子在轨道上滚动!
一个原盘滚动的例子,不过没有用Pilot<BR><BR>例题是用GUI做的,因此命令流有些乱,不过是个调通的程序:<BR>/PREP7 <BR>!* <BR>ET,1,PLANE182 <BR>!* <BR>!* <BR>MPTEMP,,,,,,,, <BR>MPTEMP,1,0 <BR>MPDATA,EX,1,,6.9e4 <BR>MPDATA,PRXY,1,,0.32 <BR>TB,BISO,1,1,2, <BR>TBTEMP,0 <BR>TBDATA,,31,200,,,, <BR>SAVE <BR>RECTNG,0,10,0,2, <BR>FLST,2,2,8 <BR>FITEM,2,10,7,0 <BR>FITEM,2,10,12,0 <BR>CIRCLE,P51X, , , ,360,4, <BR>GPLOT <BR>SAVE <BR>FLST,5,1,4,ORDE,1 <BR>FITEM,5,3 <BR>CM,_Y,LINE <BR>LSEL, , , ,P51X <BR>CM,_Y1,LINE <BR>CMSEL,,_Y <BR>!* <BR>LESIZE,_Y1, , ,20, , , , ,1 <BR>!* <BR>FLST,5,1,4,ORDE,1 <BR>FITEM,5,2 <BR>CM,_Y,LINE <BR>LSEL, , , ,P51X <BR>CM,_Y1,LINE <BR>CMSEL,,_Y <BR>!* <BR>LESIZE,_Y1, , ,5, , , , ,1 <BR>!* <BR>MSHAPE,0,2D <BR>MSHKEY,1 <BR>!* <BR>CM,_Y,AREA <BR>ASEL, , , , 1 <BR>CM,_Y1,AREA <BR>CHKMSH,'AREA' <BR>CMSEL,S,_Y <BR>!* <BR>AMESH,_Y1 <BR>!* <BR>CMDELE,_Y <BR>CMDELE,_Y1 <BR>CMDELE,_Y2 <BR>!* <BR>GPLOT <BR>SAVE <BR>!* <BR>!* <BR>/COM, CONTACT PAIR CREATION - START <BR>CM,_NODECM,NODE <BR>CM,_ELEMCM,ELEM <BR>CM,_LINECM,LINE <BR>CM,_AREACM,AREA <BR>/GSAV,cwz,gsav,,temp <BR>MP,MU,1,0.2 <BR>MAT,1 <BR>MP,EMIS,1,7.88860905221e-031 <BR>R,1 <BR>REAL,1 <BR>ET,2,169 <BR>ET,3,172 <BR>R,1,,,1.0,0.1,, <BR>RMORE,,,1.0E20,0.0,1.0, <BR>RMORE,0.0,0,1.0,0,0,0.5 <BR>RMORE,,,1.0,0.0 <BR>KEYOPT,3,2,0 <BR>KEYOPT,3,3,0 <BR>KEYOPT,3,4,0 <BR>KEYOPT,3,5,0 <BR>KEYOPT,3,7,0 <BR>KEYOPT,3,8,0 <BR>KEYOPT,3,9,0 <BR>KEYOPT,3,10,0 <BR>KEYOPT,3,11,0 <BR>KEYOPT,3,12,0 <BR>KEYOPT,2,2,0 <BR>KEYOPT,2,3,0 <BR>! Generate the target surface <BR>LSEL,S,,,5 <BR>LSEL,A,,,6 <BR>LSEL,A,,,7 <BR>LSEL,A,,,8 <BR>CM,_TARGET,LINE <BR>TYPE,2 <BR>LATT,-1,1,2,-1 <BR>TYPE,2 <BR>LMESH,ALL <BR>! Generate the contact surface <BR>LSEL,S,,,3 <BR>CM,_CONTACT,LINE <BR>TYPE,3 <BR>NSLL,S,1 <BR>ESLN,S,0 <BR>ESURF,ALL <BR>*SET,_REALID,1 <BR>ALLSEL <BR>ESEL,ALL <BR>ESEL,S,TYPE,,2 <BR>ESEL,A,TYPE,,3 <BR>ESEL,R,REAL,,1 <BR>LSEL,S,REAL,,1 <BR>/PSYMB,ESYS,1 <BR>/PNUM,TYPE,1 <BR>/NUM,1 <BR>EPLOT <BR>ESEL,ALL <BR>ESEL,S,TYPE,,2 <BR>ESEL,A,TYPE,,3 <BR>ESEL,R,REAL,,1 <BR>LSEL,S,REAL,,1 <BR>CMSEL,A,_NODECM <BR>CMDEL,_NODECM <BR>CMSEL,A,_ELEMCM <BR>CMDEL,_ELEMCM <BR>CMSEL,S,_LINECM <BR>CMDEL,_LINECM <BR>CMSEL,S,_AREACM <BR>CMDEL,_AREACM <BR>/GRES,cwz,gsav <BR>CMDEL,_TARGET <BR>CMDEL,_CONTACT <BR>/COM, CONTACT PAIR CREATION - END <BR>*CREATE,cwzplot,mac <BR>/COM, <BR>/COM,PLOT CONTACT PAIR(S) <BR>~eui,'::apdl::noprint 1' <BR>~eui,'::apdl::nooutput 1' <BR>CM,_CWZ_EL,ELEM <BR>CM,_CWZ_ND,NODE <BR>CM,_CWZ_KP,KP <BR>CM,_CWZ_LN,LINE <BR>CM,_CWZ_AR,AREA <BR>CM,_CWZ_VL,VOLU <BR>ESEL,NONE <BR>ESEL,A,REAL,,1 <BR>ESEL,R,ENAME,,169,174 <BR>NSLE <BR>KSLN,S <BR>LSLK,S,1 <BR>ASLL,S,1 <BR>/PNUM,TYPE,1 <BR>/NUM,1 <BR>/PSYMB,ESYS,0 <BR>EPLOT <BR>CMSEL,S,_CWZ_EL <BR>CMDEL,_CWZ_EL <BR>CMSEL,S,_CWZ_ND <BR>CMDEL,_CWZ_ND <BR>CMSEL,S,_CWZ_KP <BR>CMDEL,_CWZ_KP <BR>CMSEL,S,_CWZ_LN <BR>CMDEL,_CWZ_LN <BR>CMSEL,S,_CWZ_AR <BR>CMDEL,_CWZ_AR <BR>CMSEL,S,_CWZ_VL <BR>CMDEL,_CWZ_VL <BR>/PSYMB,ESYS,0 <BR>/NUM,0 <BR>/PNUM,TYPE,0 <BR>/PNUM,REAL,0 <BR>/mrep,cwzplot <BR>~eui,'::apdl::nooutput 0' <BR>~eui,'::apdl::noprint 0' <BR>*END <BR>cwzplot <BR>SAVE <BR>EPLOT <BR>TYPE, 2 <BR>MAT, 1 <BR>REAL, 1 <BR>ESYS, 0 <BR>SECNUM, <BR>TSHAP,PILO <BR>!* <BR>E, 127 <BR>SAVE <BR>FINISH <BR>/SOLU <BR>FLST,2,1,4,ORDE,1 <BR>FITEM,2,1 <BR>!* <BR>/GO <BR>DL,P51X, ,UY, <BR>FLST,2,1,4,ORDE,1 <BR>FITEM,2,4 <BR>!* <BR>/GO <BR>DL,P51X, ,UX, <BR>FLST,2,1,1,ORDE,1 <BR>FITEM,2,127 <BR>!* <BR>/GO <BR>D,P51X, ,-0.2, , , ,UY, , , , , <BR>SAVE <BR>ANTYPE,0 <BR>NLGEOM,1 <BR>NSUBST,50,500,50 <BR>OUTRES,ALL,ALL <BR>AUTOTS,1 <BR>TIME,1 <BR>/STATUS,SOLU <BR>SOLVE <BR>EPLOT <BR>FLST,2,1,4,ORDE,1 <BR>FITEM,2,4 <BR>DLDELE,P51X,UX <BR>FLST,2,1,1,ORDE,1 <BR>FITEM,2,127 <BR>!* <BR>/GO <BR>D,P51X, ,1.57, , , ,ROTZ, , , , , <BR>SAVE <BR>NSUBST,200,1000,200 <BR>/STATUS,SOLU <BR>SOLVE <BR><BR>求解后,进入后处理 <BR><BR>/POST1 <BR><BR>-999,-999, <BR>ANDATA,0.5, ,1,1,2,1,0,1 <BR>
GMT+8, 2024-11-20 20:28 , Processed in 0.066809 second(s), 17 queries , Gzip On.
