查看: 2567|回复: 1
[其他CAE] virtual lab 模态基础力响应问题
发表于 2011-1-2 20:59 | 显示全部楼层 |阅读模式
在virtual lab 中模态分析,然后在noise & vibration中做 modal-based forced response analys,计算时出现这个问题,是什么意思?所谓的static compensation points 是什么?
some input points are not used as static compensation points in the input nastran modal solution.points missing 178527:+x
发表于 2011-9-4 09:51 | 显示全部楼层
镇江的?
做哪行??
GMT+8, 2025-7-12 13:42 , Processed in 0.062014 second(s), 17 queries , Gzip On.
