查看: 4969|回复: 3
[Nastran专区] nastran提示磁盘空间不足
发表于 2010-11-30 10:12 | 显示全部楼层 |阅读模式
今天用nastran计算一个很大模型的结构模态,在log文件中出现如下
NASTRAN OP2NEW=0 MSC.Nastran.lclfileNastranBUFFSIZE=8193(d:/msc.software/msc_nastran/conf/nast2007.rcf[2])
Nastran REAL=667156480 (programdefault)JID=d:/xxue/modes250/srvstmodes250.bdfOUT=./srvstmodes250MEM=804362240 WORDS
MACH='Intel'
OPER='Windows XP'
OSV='5.1 (Build 2600)'
MODEL='PentiumIII/5100 (D6K12R2X)'
NPROC='8'
CONFIG=6
NPROC=8
symbol=DELDIR='d:/msc.software/msc_nastran/msc2007/nast/del' (programdefault)symbol=DEMODIR=d:/msc.software/mscnastran/msc2007/nast/demo(program default)
symbol=LM_NO_SNMP=1 (d:/msc.software/mscnastran/conf/nast2007.rcf[5])symbol=SSSALTERDIR=d:/msc.software/mscnastran/msc2007/nast/sssalter(program default)
symbol=TPLDIR='d:/msc.software/msc_nastran/msc2007/nast/tpl' $(program default)
SDIR='d:/scratch/srv_stmodes_250.T2128_53'
DBS='d:/scratch/srv_stmodes_250.T2128_53'
SCR=yes
NEWDEL='d:/msc.software/msc_nastran/msc2007/i386/SSS'
DEL='MSCDEF'
AUTH='D:\MSC.Software\MSC.Licensing\10.8\license.dat'
AUTHQUE=20
MSGCAT='d:/msc.software/msc_nastran/msc2007/i386/analysis.msg'
MSGDEST='f06'
NEWS='d:/msc.software/msc_nastran/msc2007/nast/news.txt'
Current resource limits:
Physical memory:                     2557 MB
Physical memory available:           2055 MB
Paging file size:                    6480 MB
Paging file size available:          6081 MB
Virtual memory:                      2047 MB
Virtual memory available:            2027 MB
MSC.Nastran started  Tue Nov 30 09:53:53 ?2010
09:53:54  Beginning Analysis
All SSE XMM operations have been enabled.
All MMX operations have been enabled.
All FPU operations have been enabled.
09:53:54  MSC Authorization Information - System Attributes (1004, 0)
09:53:54  -----------------------------------------------------------
  Date:          Tue Nov 30 09:53:54 2010
  MSC Id:        0024e84953af (ethernet)
  Hostname:      D6K12R2X
  Host Type:     Intel  Server List:   Host: D6K12R2X  Id: 0024e84953af (ethernet)  Comm: 0  Port: 1700
  License files: D:\MSC.Software\MSC.Licensing\10.8\license.dat
  User:          ISVR
  Display:       D6K12R2X
  * *   MSC Customer Entitlement ID   * *
  * *        E84953AF-BBBG75EA        * *
09:53:55  MSC Authorization Information - Checkout Successful (1016, 0)
09:53:55  -------------------------------------------------------------
09:53:55  Acquired 1 license for MSC.Nastran
The maximum available OPEN CORE size is 385727482 words.
Unable to allocate /XNSTRN/ Open Core.
Requested size = 2047352576 bytes (7A081F00 hex)
  GetLastError() returned 8 ("存储空间不足,无法处理此命令。").
Virtual Storage Map
Start Address    Length  State        Type         Protect                  Image/Mapped File Name
请问一下各位高手,怎么处理这个问题
发表于 2010-11-30 22:44 | 显示全部楼层
你的nastran装在D盘,工作目录也在D盘,要确保你的D盘有足够的空间。
你现在的设置是d:/scratch,找到nastran的安装目录,找到conf的文件把scratch的目录改到盘符大的盘,用nastran直接调用你的文件计算试试
 楼主| 发表于 2010-12-1 15:18 | 显示全部楼层
回复 2 # 唯有时光 的帖子
空间足够大,conf文件中memory=estimate,软件估计的存储空间不够
我想请教一下memory应该怎么改才好?
发表于 2010-12-2 00:39 | 显示全部楼层
回复 3 # gb102700 的帖子
这个问题我还没遇到过,应该是你的模型太大
如果网格可以精简的话可以考虑进行精简;nastran计算时的内存调用应该是动态的,是根据问题的规模自适应选择的,建议不要改变该参数,而且你的Requested size已经2047Mb了,这个大小已经跟你的物理可用内存2055 MB接近,已经没有再扩大的空间了。
GMT+8, 2025-8-5 07:13 , Processed in 0.096553 second(s), 17 queries , Gzip On.
