查看: 2898|回复: 9
[编程技巧] 【求助】悬置MATLAB优化
发表于 2010-11-10 16:01 | 显示全部楼层 |阅读模式
大家好,我现在有一振动模型,具体算法如下:
  1. clear
  2. clc
  3. %动力总成质量
  4. m=323.98;%kg
  5. %惯性积
  6. Jx=25.706;Jy=13.607;Jz=23.014;Jxy=-3.029;Jyz=3.359;Jzx=-0.876;%kg*m*m
  7. %各个悬置点坐标
  8. Xz=72.44;Yz=-431.92;Zz=148.82;
  9. Xy=4.34;Yy=452.98;Zy=250.22;
  10. Xh=199.64;Yh=-7.72;Zh=-245.93;
  11. %mm在下面将位移坐标变成m
  12. %各个悬置的三向刚度
  13. Kzx=380e3*1.5;Kzy=72e3*1.5;Kzz=220e3*1.5;
  14. Kyx=380e3*1.5;Kyy=72e3*1.5;Kyz=220e3*1.5;
  15. Khx=213e3*1.5;Khy=10e3*1.5;Khz=10e3*1.5;%N/m
  16. %各个悬置的安装角度
  17. %左悬置安装角度
  18. ALFAzu=0;BETAzu=90*pi/180;GAMAzu=90*pi/180;
  19. ALFAzv=90*pi/180;BETAzv=0;GAMAzv=90*pi/180;
  20. ALFAzw=90*pi/180;BETAzw=90*pi/180;GAMAzw=0;
  21. %右悬置安装角度
  22. ALFAyu=0;BETAyu=90*pi/180;GAMAyu=90*pi/180;
  23. ALFAyv=90*pi/180;BETAyv=0;GAMAyv=90*pi/180;
  24. ALFAyw=90*pi/180;BETAyw=90*pi/180;GAMAyw=0;
  25. %后悬置安装角度
  26. ALFAhu=8*pi/180;BETAhu=90*pi/180;GAMAhu=82*pi/180;
  27. ALFAhv=90*pi/180;BETAhv=0;GAMAhv=90*pi/180;
  28. ALFAhw=98*pi/180;BETAhw=90*pi/180;GAMAhw=8*pi/180;
  29. %安装角矩阵Tj
  30. Th=[cos(ALFAhu),cos(BETAhu),cos(GAMAhu);cos(ALFAhv),cos(BETAhv),cos(GAMAhv);cos(ALFAhw),cos(BETAhw),cos(GAMAhw)];
  31. Tz=[cos(ALFAzu),cos(BETAzu),cos(GAMAzu);cos(ALFAzv),cos(BETAzv),cos(GAMAzv);cos(ALFAzw),cos(BETAzw),cos(GAMAzw)];
  32. Ty=[cos(ALFAyu),cos(BETAyu),cos(GAMAyu);cos(ALFAyv),cos(BETAyv),cos(GAMAyv);cos(ALFAyw),cos(BETAyw),cos(GAMAyw)];
  33. %参数输入完毕
  34. %%%%%%%%%%%====================%%%%%%%%%%
  35. %%%%%%%%%%%---能量表达式中的Fj和kj---%%%%%%%%%%
  36. Fh=[1e3,0,0,0,Zh,-Yh;0,1e3,0,-Zh,0,Xh;0,0,1e3,Yh,-Xh,0]*0.001;
  37. Fz=[1e3,0,0,0,Zz,-Yz;0,1e3,0,-Zz,0,Xz;0,0,1e3,Yz,-Xz,0]*0.001;
  38. Fy=[1e3,0,0,0,Zy,-Yy;0,1e3,0,-Zy,0,Xy;0,0,1e3,Yy,-Xy,0]*0.001;
  39. %%%此处将位移坐标转变成m
  40. kh=[Khx,0,0;0,Khy,0;0,0,Khz];
  41. kz=[Kzx,0,0;0,Kzy,0;0,0,Kzz];
  42. ky=[Kyx,0,0;0,Kyy,0;0,0,Kyz];
  43. %%%%%%%%%%%---振动方程中的M,D和K---%%%%%%%%%%
  44. M=[m,0,0,0,0,0;0,m,0,0,0,0;0,0,m,0,0,0;0,0,0,Jx,-Jxy,-Jzx;0,0,0,-Jxy,Jy,-Jyz;0,0,0,-Jzx,-Jyz,Jz];
  45. % D=[1200,0,0,0,0,0;0,1600,0,0,0,0;0,0,2000,0,0,0;0,0,0,60,0,0;0,0,0,0,80,0;0,0,0,0,0,100];
  46. K=Fh'*Th'*kh*Th*Fh+Fz'*Tz'*kz*Tz*Fz+Fy'*Ty'*ky*Ty*Fy;
  47. %%%%%%%%%%%%%---下面计算系统固有特性---%%%%%%%%%%%%%
  48. [v,d]=eig(K,M);
  49. f=diag(sqrt(d)/2/pi)'
  50. for j=1:6
  51. for k=1:6
  52. for l=1:6
  53. ENERGY(k,l)=M(k,l)*v(k,j)*v(l,j);
  54. end
  55. end
  56. qq=sum(ENERGY);
  57. qqt=sum(qq);
  58. dig=[qq/qqt];
  59. EGEN(:,j)=dig;
  60. ep1=max(dig);
  61. ep2=sum(dig);
  62. eper(j)=ep1/ep2*100;
  63. end
  64. eper
  65. EGEN=EGEN*100
程序前面是参数的输入和一些坐标变换,最后求出来的是系统的固有频率f,能量矩阵EGEN(对应6乘6的矩阵),eper对应EGEN每列最大值。
我现在想提高eper的值,理论上可以通过修改刚度K得到,现在以
object=-sum(max(EGEN))为目标函数:
约束条件为:
(1)程序里面的Kzx、Kzy、Kzz;Kyx、Kyy、Kyz;Khx、Khy、Khz,想把这些刚度值设一个上限和下下限。
(2)还要把求出来的f(i)作为约束条件,设定6个f(i)的范围。
我参考了fmincon、fgoalattain等多个函数,也做过了一些例子,但是对于自己这个问题还是无从下手,希望大家能提供一点思路和帮助,现在急需最后优化的刚度值。
在线等候各位的提示,谢谢,不甚感激。。。
我的邮箱:zs.jordan@163.com
发表于 2010-11-10 19:23 | 显示全部楼层
这个应该到振动或是物理那些论坛去看一下...
这里就是振动!? :)  发表于 2010-11-22 00:27
发表于 2010-11-21 17:51 | 显示全部楼层
我也有此问题 ,请联系wliang_auto@hotmail.com.3q
发表于 2010-11-21 18:18 | 显示全部楼层
这个问题用fmincon应该可以实现,大概考虑了一下,基本格式应该可以通过下面的格式实现
x = fmincon(@myfun,x0,A,b,Aeq,beq,lb,ub,@mycon)
对应函数中的@myfun
约束条件1:对应A,b
约束条件2:对应@mycon
估计你的主要问题应该出现在约束条件2上
具体你可以参考帮助文件中的nonlcon项的相关说明
赞成: 3.0
赞成: 3
  发表于 2014-3-27 16:05
发表于 2010-11-22 00:55 | 显示全部楼层
LZ的另一相同意议题的帖
http://forum.vibunion.com/thread-97216-1-1.html
 楼主| 发表于 2010-11-22 12:35 | 显示全部楼层
嘿嘿,经过几天的调试,已经做出来了。
开始就是约束函数没注意,频率范围设置的时候要包含原始值在内,不然计算不收敛。
谢谢各位。
发表于 2014-3-27 15:38 | 显示全部楼层
LAN博基尼 发表于 2010-11-22 12:35
嘿嘿,经过几天的调试,已经做出来了。
开始就是约束函数没注意,频率范围设置的时候要包含原始值在内,不 ...
您好,我也用matlab中fmincon编了解耦程序,跟你说的差不多,频率设置时候需要注意。但是这样一来,
如果想要优化到想要的频率,那就无法计算了,用这个fmincon就只能增大解耦率。请问你的程序是吗?
谢谢
GMT+8, 2025-8-1 04:56 , Processed in 0.089542 second(s), 25 queries , Gzip On.
