查看: 3578|回复: 1
[结构分析] 弹性联轴器尽力学分析
发表于 2010-11-3 13:04 | 显示全部楼层 |阅读模式
*** WARNING ***                         CP =       0.703   TIME= 12:34:10
Use of the -M switch is no longer recommended for normal ANSYS use.
ANSYS now dynamically allocates memory as needed.  Only use the -M
switch if you are certain that you need to do so.
*** WARNING ***                         CP =       7.719   TIME= 12:34:17
Element shape checking is currently inactive.  Issue SHPP,ON or
SHPP,WARN to reactivate, if desired.
*** WARNING ***                         CP =       7.844   TIME= 12:34:17
SOLID186 wedges are recommended only in regions of relatively low
stress gradients.
*** ERROR ***                           CP =      14.531   TIME= 12:34:21
Element 34365 requires material properties and references material
number 5 for which no properties are defined.  Checking terminates.
*** ERROR ***                           CP =      14.578   TIME= 12:34:21
The step data was checked and there were errors found.
  Please check output or errors file ( D:\ZYMCOUPLE\ANSY\01 Simulation
Files\Static Structural (3)\file.err ) for messages.
发表于 2010-11-7 08:05 | 显示全部楼层
该警告是内存问题查看:http://forum.vibunion.com/thread-25587-1-1.html
该警告说明网格有问题,网格质量不好
stress gradients.
SOLID45单元只用在应力梯度较低的区域
材料5没有定义
  Please check output or errors file ( D:YMCOUPLEANSY1 Simulation
FilesStatic Structural (3)file.err ) for messages.
GMT+8, 2025-1-11 14:32 , Processed in 0.088273 second(s), 18 queries , Gzip On.
