查看: 2697|回复: 3
[理论方法] 再议包络谱分析
发表于 2010-9-22 00:31 | 显示全部楼层 |阅读模式
LabVIEW关于包络分析的说明,The envelope detection technique involves the following three steps: shifting the narrow band range in the high frequency band to the base band,
filtering the frequency-shifted signal using a lowpass filter, and calculating the envelope signal of the lowpass-filtered signal。现在不敢确定用hilbert法做包络谱是否与它一致,后两步肯定没问题,就是第一步好像有差异,虽然hilbert法效果也可以。
 楼主| 发表于 2010-9-22 19:46 | 显示全部楼层
发一下hilbert法求包络谱与labVIEW包络谱比较图。数据取自LabVIEW Sound and Vibration Measurement Suite中的包络谱分析,数据中包含一个外圈故障频率(Outer race frequency)—约61.6Hz,工作转速频率在20.6Hz左右。
发表于 2012-11-24 19:47 | 显示全部楼层
impulse 发表于 2010-9-22 19:46
发一下hilbert法求包络谱与labVIEW包络谱比较图。数据取自LabVIEW Sound and Vibration Measurement Suite中 ...
用的哪个函数vi, 我想试一下,也想自己写一个包络谱,
 楼主| 发表于 2012-11-25 21:22 | 显示全部楼层
声学振动工具包里的OAT Envelope Detection VI
GMT+8, 2024-11-18 06:48 , Processed in 0.064017 second(s), 19 queries , Gzip On.
