查看: 11929|回复: 5
[Nastran专区] nastran计算求助
发表于 2010-7-2 00:55 | 显示全部楼层 |阅读模式
在结构动态仿真中,同一模型,同一激励源,在计算响应时一个算了1000步,一个算了4000步,为什么1000步时能计算,4000步时就没法计算了,f06文件的部分信息中,有个一
warning  “USER WARNING MESSAGE 7697 (GKAM1A)
     ONE OR MORE MODAL DAMPING VALUES FOR STRUCTURE MODES ARE EITHER NEGATIVE OR HAVE RESULTED FROM EXTRAPOLATION OF THE TABDMP1”这应该是说刚体模态阻尼和结构模态阻尼。
还有个 fatal message
*** USER FATAL MESSAGE 1012 (GALLOC)
     DBSET DBALL    IS FULL AND NEEDS TO BE EXPANDED.
     USER ACTION: SEE THE MSC.NASTRAN INSTALLATION AND OPERATIONS GUIDE OR
                  TAN 4893 ON THE MSC WEB SITE FOR METHODS TO MAKE LARGER DATABASES.
     BIOMSG: ERROR   4276 HAS OCCURRED IN ROUTINE GALLOC  , FILE INDEX =            0.
     STATUS =          0
********* NASTRAN FILE TABLE *********
我觉得应该是这个fatal message的原因,可是没看懂,说什么dball文件,哪位大虾帮忙给看下呢,指点迷津啊,鄙人刚接触有限元,不懂啊。
下面是f06里的部分信息
0
1   THIS IS A DEFAULT SUBCASE.                                                 JULY   1, 2010  MSC.NASTRAN  6/19/08   PAGE   836
0        SUBCASE 85
*** USER WARNING MESSAGE 7697 (GKAM1A)
     TABDMP1 1 TABLE DATA AS SHOWN BELOW:
     CYCLIC FREQUENCY =  1.348780E+04  MODAL DAMPING VALUE =  1.000000E-01  (BY EXTRAPOLATION BEYOND THE RIGHT END OF THE TABLE)
1   THIS IS A DEFAULT SUBCASE.                                                 JULY   1, 2010  MSC.NASTRAN  6/19/08   PAGE   837
0        SUBCASE 85
*** USER INFORMATION MESSAGE 7559 (TRLGP)
     THIS TRANSIENT RESPONSE ANALYSIS INVOLVES THE FOLLOWING TYPES OF EXCITATION --
     * APPLIED LOADS
*** USER INFORMATION MESSAGE 5222 (TRD1)
     UN COUPLED SOLUTION ALGORITHM USED.
     STATUS =          0
INDEX  LOGNAME         STREAM_ID     NAME
     1  SCRATCH         00000001      c:/scratch/armature-sin1.85-4000.T3104_28.SCRATCH
     2  OBJSCR          00000002      c:/scratch/armature-sin1.85-4000.T3104_28.OBJSCR
     3  MASTER          00000003      ./armature-sin1.85-4000.MASTER
     4  DBALL           00000004      ./armature-sin1.85-4000.DBALL
     5  SCR300          00000005      c:/scratch/armature-sin1.85-4000.T3104_28.SCR300
     6  MASTERA         FFFFFFFA      c:/msc.software/msc_nastran/msc2008/i386/SSS.MASTERA
     7  MSCOBJ          FFFFFFF9      c:/msc.software/msc_nastran/msc2008/i386/SSS.MSCOBJ
*** SYSTEM FATAL MESSAGE 4276 (GALLOC)
     ERROR CODE     4276 PID=   0
*** USER INFORMATION MESSAGE 4276 (GALLOC)
     THE DIAG 44 RELATED A NASTRAN DUMP IS SENT TO LOG FILE.
     USER ACTION: THIS INFORMATION MAY BE USEFUL TO MSC FOR DEBUGGING YOUR PROBLEM.
                  PLEASE CONTACT MSC CLIENT SUPPORT.
1                                        * * * END OF JOB * * *
*** SYSTEM INFORMATION MESSAGE 1156 (XCLNUP)
     GINO FILE      101 WAS LEFT OPEN AT PROGRAM TERMINATION.
     GINO FILE      201 WAS LEFT OPEN AT PROGRAM TERMINATION.
     GINO FILE      102 WAS LEFT OPEN AT PROGRAM TERMINATION.
     GINO FILE      103 WAS LEFT OPEN AT PROGRAM TERMINATION.
     GINO FILE      202 WAS LEFT OPEN AT PROGRAM TERMINATION.
     GINO FILE      203 WAS LEFT OPEN AT PROGRAM TERMINATION.
No Symbolic Replacement variables or values were specified.
 楼主| 发表于 2010-7-5 23:11 | 显示全部楼层
版主给点意见,或者有没有已经解决的兄弟姐妹给点意见啊
发表于 2010-7-6 20:18 | 显示全部楼层
外行人的意见, 考量将问题转换为更一般性, 或许回答的会比较多!
发表于 2010-7-28 19:55 | 显示全部楼层
还有个 fatal message
     STATUS =          0
!!!!!!!!!!!!磁盘空间不够吧
 楼主| 发表于 2010-8-3 23:11 | 显示全部楼层
已解决。不计算相关节点信息,可节省大量计算空间
发表于 2010-8-17 10:07 | 显示全部楼层
1012的msg有一般的解决办法,首先是结果中不要生成dball文件,计算控制中添加“scr=yes”的语句,另外更普遍的解决办法是缩小你的模型,只求解你所关心的物理量,比如应力的计算通常会占用较大的磁盘空间,因此就要考虑是不是要输出。如果1000步可以满足结果输出要求,那就不要4000步。
GMT+8, 2025-7-27 16:48 , Processed in 0.066537 second(s), 19 queries , Gzip On.
