查看: 1148|回复: 2
[结构分析] 新手求助:平面应力问题(孔加载问题)
发表于 2010-6-25 22:48 | 显示全部楼层 |阅读模式
问题是压缩机连杆,按照平面应力计算,在两个支撑孔上作用有沿中心且大小相等的压力F=100N,,我想问的是我该怎样加这个力了?曾经想过两种思路,一种是在中心线的两个关键点上加,另一种是把100N的力均布到孔边的节点上,使之方向沿中线线.但是好象这些做法都是错误的,所以在次求指导.谢谢啊!
finish
/clear
/prep7
pcirc,1.4,1,0,180
pcirc,1.4,1,45,180
/pnum,area,1
aplot
rectng,-0.3,0.3,1.2,1.8
rectng,-1.8,-1.2,0,0.3
wpstyle,,,,,,,,,1
wpave,6.5
csys,4
pcirc,0.7,0.4,0,180
pcirc,0.7,0.4,0,135
/auto,1
aplot
aovlap,1,2,3,4
aovlap,5,6
csys,0
k,,2.5,0.5
k,,3.25,0.4
k,,4,0.33
k,,4.75,0.28
csys,1
bsplin,5,6,7,21,24,22,1,135,,1,45
lstr,1,18
/pnum,line,1
lplot
al,6,1,7,25
lfillt,36,40,0.25
lfillt,40,31,0.25
lfillt,30,39,0.25
lplot
al,12,10,13
al,17,15,19
al,23,21,24
aadd,all
aplot
save
et,1,plane82
mp,ex,1,2e5
mp,prxy,1,0.3
esize,0.2
mshape,0,2d
mshkey,0
amesh,all
save
eplot
/sol
FLST,2,7,4,ORDE,7
FITEM,2,4
FITEM,2,7
FITEM,2,18
FITEM,2,20
FITEM,2,32
FITEM,2,35
FITEM,2,38
DL,P51X, ,SYMM
FLST,2,1,3,ORDE,1
 楼主| 发表于 2010-6-26 15:31 | 显示全部楼层
问了一下,好象通过把力均布在孔边的节点上是可以的
发表于 2010-6-28 20:44 | 显示全部楼层
Wp可以施加轴承约束
GMT+8, 2024-10-1 07:34 , Processed in 0.064660 second(s), 19 queries , Gzip On.
