查看: 1503|回复: 4
[求助]大家帮我看看mex环境设置问题(以解决)
发表于 2006-4-1 10:38 | 显示全部楼层 |阅读模式
&gt;&gt; mex -setup<br>Please choose your compiler for building external interface (MEX) files: <br><br>Would you like mex to locate installed compilers [y]/n? y<br><br>Select a compiler: <br>[1] Digital Visual Fortran version 6.0 in C:\Program Files\Microsoft Visual Studio <br>[2] Lcc C version 2.4 in C:\MATLAB6P5\sys\lcc <br>[3] Microsoft Visual C/C++ version 6.0 in C:\Program Files\Microsoft Visual Studio <br><br>[0] None <br><br>Compiler: 3<br><br>Please verify your choices: <br><br>Compiler: Microsoft Visual C/C++ 6.0 <br>Location: C:\Program Files\Microsoft Visual Studio <br><br>Are these correct?([y]/n): y<br><br>The default options file: <br>"C:\Documents and Settings\Administrator\Application Data\MathWorks\MATLAB\R13\mexopts.bat" <br>is being updated from C:\MATLAB6P5\BIN\WIN32\mexopts\msvc60opts.bat... <br><br>Installing the MATLAB Visual Studio add-in ... <br><br>  Updated C:\Program Files\Microsoft Visual Studio\common\msdev98\template\MATLABWizard.awx <br>    from C:\MATLAB6P5\BIN\WIN32\MATLABWizard.awx <br>  Updated C:\Program Files\Microsoft Visual Studio\common\msdev98\template\MATLABWizard.hlp <br>    from C:\MATLAB6P5\BIN\WIN32\MATLABWizard.hlp <br>  Updated C:\Program Files\Microsoft Visual Studio\common\msdev98\addins\MATLABAddin.dll <br>    from C:\MATLAB6P5\BIN\WIN32\MATLABAddin.dll <br>  Merged C:\MATLAB6P5\BIN\WIN32\usertype.dat <br>    with C:\Program Files\Microsoft Visual Studio\common\msdev98\bin\usertype.dat <br><br><FONT color=#f70909>&gt;&gt; <FONT style="BACKGROUND-COLOR: #2bd52b">mex yprime改为mex yprime.c,then ok<br></FONT></FONT><br>  C:\MATLAB6P5\BIN\WIN32\MEX.PL: Error: 'yprime' not found. <br><br>??? Error using ==&gt; mex<br>Unable to complete successfully
[此贴子已经被cdwxg于2006-6-3 11:56:22编辑过]
发表于 2006-4-1 17:02 | 显示全部楼层
回复:(_distance)大家帮我看看mex环境设置问题
<DIV class=quote><B>以下是引用<I>_distance</I>在2006-4-1 10:38:11的发言:</B><BR>&gt;&gt; mex yprime<BR><BR>  C:\MATLAB6P5\BIN\WIN32\MEX.PL: Error: <FONT color=#ff0000>'yprime' not found</FONT>. <BR><BR>??? Error using ==&gt; mex<BR>Unable to complete successfully<BR></DIV>
<P>没有找到yprime文件,看看工作目录下有没有这个文件吧</P>
 楼主| 发表于 2006-4-1 19:12 | 显示全部楼层
happy兄,我已经把yprime考到work目录下了,就是不行
发表于 2006-4-2 10:22 | 显示全部楼层
回复:(_distance)大家帮我看看mex环境设置问题(以解...
<DIV class=quote><B>以下是引用<I>_distance</I>在2006-4-1 10:38:11的发言:</B><BR><BR><FONT color=#f70909>&gt;&gt; <FONT style="BACKGROUND-COLOR: #2bd52b">mex yprime改为mex yprime.c,then ok<BR></FONT></FONT><BR><BR></DIV>
<P><BR>呵呵,这个错误啊</P>
发表于 2006-6-3 10:11 | 显示全部楼层
问题最后怎么解决的<BR>谢谢!!!!!!!!!!
GMT+8, 2024-10-4 11:16 , Processed in 0.054407 second(s), 18 queries , Gzip On.
