查看: 1126|回复: 0
[综合讨论] 请大家帮我看下
发表于 2010-4-18 14:58 | 显示全部楼层 |阅读模式
The algorithm used to create the modal neutral file (.MNF) is based on a formulation called component mode synthesis (also known as dynamic substructuring). ADAMS uses the approach of Craig -Bampton with some slight modifications.
上面是ANSYS帮助文档里关于ANSYS生成模态中性文件的一句话,小弟理解的不是很准确,请大家指点,谢谢
GMT+8, 2024-11-19 04:26 , Processed in 0.080524 second(s), 17 queries , Gzip On.
