查看: 1536|回复: 1
[结构分析] 请问:轴对称问题
发表于 2010-4-13 19:22 | 显示全部楼层 |阅读模式
3维的圆柱体中心施加集中力载荷,但是为了简便,我建了2维轴对称结构模型,底部限制运动,向原点处的节点施加集中力,见图,为什么求解不收敛,并且显示节点316 zero radius at Gauss Point?好像变形得很厉害。。。附上我的代码。。。
下载 (3.85 KB)
求解后的变形图
1 分钟前
/PREP7
ET,1,PLANE182
KEYOPT,1,1,0
KEYOPT,1,3,1
KEYOPT,1,6,0
KEYOPT,1,10,0
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,60E3
MPDATA,PRXY,1,,0.45
RECTNG,0,0.0225,0,-0.0045,
AATT,       1, ,   1,       0,
FLST,2,1,5,ORDE,1
FITEM,2,1
AESIZE,P51X,0.0005,
MSHAPE,0,2D
MSHKEY,1
CM,_Y,AREA
ASEL, , , ,       1
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
FINISH
/SOLU
ANTYPE,0
ANTYPE,0
NLGEOM,1
NSUBST,200,1000,10
OUTRES,ERASE
OUTRES,ALL,ALL
AUTOTS,1
TIME,100
FLST,2,1,4,ORDE,1
FITEM,2,1
/GO
DL,P51X, ,ALL,0
FLST,2,1,4,ORDE,1
FITEM,2,4
/GO
DL,P51X, ,UX,0
FLST,2,1,1,ORDE,1
FITEM,2,56
/GO
F,P51X,FY,-1.024
SOLVE
我是看见ansys 11.0的help里关于对称单元的载荷:
All nodes along the y-axis centerline (at x = 0.0) should have the radial displacements (UX if not rotated) specified as zero, unless a pinhole effect is desired. At least one value of UY should be specified or constrained to prevent rigid body motions.
所以设置了ux=0(x=0),但求解为什么还会有问题呢?
发表于 2010-11-3 16:21 | 显示全部楼层
图形看不到
轴对称模型做起来确实很复杂
模型很简单
但是边界条件是人去设定的轴对称边界条件
所以,总有可能失误!
GMT+8, 2025-1-11 14:15 , Processed in 0.072158 second(s), 17 queries , Gzip On.
