查看: 1646|回复: 0
[其他相关] 音圈参数设置请教(ansys计算出来的阻抗结果为理论值的2倍)
发表于 2010-4-6 16:26 | 显示全部楼层 |阅读模式
ansys中进行谐响应分析求音圈阻抗时,阻抗为15.7861,阻抗结果与7.8相差一倍 ,请
帮忙看看哪里出错了!
线圈外径:9.0mm
内径:8.75mm
匝数:34
层数:2
线径:0.055mm
电阻为:7.8
ρ=RS/L
ρ=1.946e-8
S
3.14*0.055^2/4*1e-6=2.37e-9m^2
为单匝线圈截面积
R
7.8Ω
L =3.14*8.875*34=0.95m
截面积为:1.625e-7
填充因子:s/(0.125*1.3*1e-6)=0.4959
/prep7
/title,stranded coil in free space
et,1,53,,,1 ! air
et,2,53,2,,1! voltage forced coil
et,3,110,,,1
emunit,mks
mp,murx,1,1
mp,murx,2,1
mp,rsvx,2,1.946e-8! resistivity of coil
a=4.375e-3
b=1.3e-3
s=0.25e-3
rectng,a,a+s,-b/2,b/2
pcirc,0,6*b,-90,90
pcirc,0,12*b,-90,90
aovlap,all
numcmp,area
/REPLOT
asel,s,area,,1
aatt,2,1,2
asel,s,area,,2
aatt,1,1,3
asel,all
FLST,2,1,5,ORDE,1  !网格划分
FITEM,2,3
FLST,5,2,4,ORDE,2
FITEM,5,2
FITEM,5,4
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,50, , , , ,1
FLST,5,2,4,ORDE,2
FITEM,5,1
FITEM,5,3
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,10, , , , ,1
FLST,5,2,4,ORDE,2
FITEM,5,5
FITEM,5,8
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,30, , , , ,1
FLST,5,2,4,ORDE,2
FITEM,5,11
FITEM,5,-12
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,1, , , , ,1
FLST,2,1,5,ORDE,1
FITEM,2,3
AESIZE,P51X,1e-3,
FLST,5,3,5,ORDE,2
FITEM,5,1
FITEM,5,-3
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
MSHKEY,2
AMESH,_Y1
MSHKEY,0
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
r,1, 1.625e-7,34, , ,0.4959
esel,s,mat,,2 ! get coil elements
nsle,s
cp,1,curr,all ! couple curr dof in coil
allsel,all
csys,1
nsel,s,loc,x,12*b
sf,all,inf! set infinite surface flag
csys,0
nsel,s,loc,x,0
d,all,az,0 ! flux-parallel condition
allsel,all
finish
/solu
antype,harm
esel,s,mat,,2
bfe,all,vltg,,1.26! 12 volts load (real)
esel,all
HARF,100,
solve
finish
/post1
ESEL,S,MAT,,2
ETABLE,inductance,NMISC,9
ETABLE,impendance,NMISC,8
SSUM
GMT+8, 2025-7-13 01:40 , Processed in 0.054302 second(s), 18 queries , Gzip On.
