查看: 2560|回复: 1
UEL自定义子程序计算时候报错
发表于 2010-4-5 19:50 | 显示全部楼层 |阅读模式
log文件如下:
Abaqus JOB PLATEUEL
Abaqus 6.9-1
Begin Compiling Abaqus/Standard User Subroutines
3/25/2010 9:31:51 PM
End Compiling Abaqus/Standard User Subroutines
3/25/2010 9:31:56 PM
Begin Linking Abaqus/Standard User Subroutines
   Creating library standardU.lib and object standardU.exp
Microsoft (R) Manifest Tool version 5.2.3790.2014
Copyright (c) Microsoft Corporation 2005.
All rights reserved.
End Linking Abaqus/Standard User Subroutines
3/25/2010 9:31:57 PM
Begin Analysis Input File Processor
Run pre.exe
Abaqus License Manager checked out the following licenses:
Abaqus/Standard checked out 5 tokens.
3/25/2010 9:32:02 PM
End Analysis Input File Processor
Begin Abaqus/Standard Analysis
Run standard.exe
3/25/2010 9:32:05 PM
Abaqus Error: The executable D:\ABAQUS\6.9-1\exec\standard.exe
aborted with system error code 144.
Please check the .dat, .msg, and .sta files for error messages if the files
exist.  If there are no error messages and you cannot resolve the problem,
please run the command "abaqus job=support information=support" to report and
save your system information.  Use the same command to run Abaqus that you
used when the problem occurred.  Please contact your local Abaqus support
office and send them the input file, the file support.log which you just
created, the executable name, and the error code.
Abaqus/Analysis exited with errors
请问各位高手,这种错误是调用的问题还是我子程序编写的问题,亦或者是INP文件的问题?自己实在是摸不着头脑,研究了好长时间没有结果
Ps:我计算别个简单的现成的UEL是可以通过的,并且有结果。
发表于 2010-4-6 13:14 | 显示全部楼层
编译没问题,你要看看dat msg文件中有没有错误??
GMT+8, 2025-1-28 00:11 , Processed in 0.170366 second(s), 18 queries , Gzip On.
