查看: 4622|回复: 6
[ADAMS专区] ADAMS 仿真中遇到的问题
发表于 2010-3-26 22:50 | 显示全部楼层 |阅读模式
ERROR:      ***** ADAMS MEMORY OVERFLOW *****
   A larger MD array is required.
   The error occurred in subroutine "SYMFAC" while allocating " INTE" space
   from "TEMP" for the "JCOL array".
   Space Available:  12421    Space Requested:  51523
   ADAMS/Solver requires more program memory to run this model.
   Be aware that the above figures for Space available and Space
   requested only reflect the current requirements.  Additional space
   may be required later in the solution process.
   Several off-the-shelf memory configurations are available and
   custom configurations may be created.  The available memory models
   and the corresponding array sizes are:
          NAME         MDSIZ
        STANDARD    1,100,000
        LARGE       3,000,000
        EX-LARGE   20,000,000
        HUGE       60,000,000
   where MDSIZ is the size in words (one word is 4 bytes) of the MD array,
   the main memory array in ADAMS in words (one word is 4 bytes).
   To use an alternative setting, you have to start the ADAMS 'Settings'
   program.  It can be found using the Start menu:
     Start -> Programs -> MSC.Software -> MSC.ADAMS -> ADAMS-Settings
ERROR:   Abnormal termination encountered in ADAMS/Solver.
我已经尝试过了,Start -> Programs -> MSC.Software -> MSC.ADAMS -> ADAMS-Settings,设置Asolver memsize为huge,下面那个没有设置,但是还是出问题,同样的问题,为什么呢?
发表于 2011-3-15 11:32 | 显示全部楼层
过约束了吧!删掉不必要的约束或简化模型
发表于 2011-3-15 15:13 | 显示全部楼层
这是由于模型太大,造成软件内存不足的情况,修改方法:
点击开始-程序-MSC.software-MSC.ADAMS-ADAMS-settings打开对话框,
将Aview和Asolver的Preferences一项右侧的memSize改为huge即可。
之后关掉ADAMS,重新打开并仿真就不会出错了。
发表于 2011-3-19 10:05 | 显示全部楼层
哦 ,原来如此。也是我的问题。我也是刚刚学起,呵呵
发表于 2012-5-10 08:40 | 显示全部楼层
你好我的adams-setting打不开怎么办啊
发表于 2013-7-10 21:29 | 显示全部楼层
受教了。。。
发表于 2013-11-26 16:14 | 显示全部楼层
你好,我的adams-setting点开闪一下黑框就消失了,该如何解决这个问题呢? win7 64位安装的adams2010
GMT+8, 2025-6-23 04:01 , Processed in 0.102332 second(s), 18 queries , Gzip On.
