查看: 2770|回复: 1
[Fortran] 一个返回复数的函数,老是出错,请师兄弟们帮忙看看
发表于 2010-3-22 01:21 | 显示全部楼层 |阅读模式
程序很简单,计算平方根,返回复数值,结果编译警告三个,说第0个形参与实参类型不对。运行结果说access violation
    program main
complex(8) x
x=sqrt1(2.0)
print*, x
end program main
complex(8) function sqrt1(a)
   real(8)::x,e=1E-4,p,q,x0=1.0
   real(8) a
   parameter(N=1E8)
   logical::s=.false.
   x=abs(a)
   p=(x0+x/x0)/2
   do i=1,N
      q=(p+x/p)/2
   if (abs(q-p)<=e) then
      s=.true.
   exit
      else
         p=q
   endif
enddo
   if (s==.false.) then
      sqrt=-1
   print *,'The Method failed'
   return
   endif
   if (a<0) then
       sqrt1=cmplx(0,q)
   else
       sqrt1=cmplx(q,0)
   endif
end function
编译警告:
E:\fortran works\numeric1\test.f90(3) : Warning: In the call to SQRT1, actual argument #0 does not match the type and kind of the corresponding dummy argument.
x=sqrt1(2.0)
E:\fortran works\numeric1\test.f90(3) : Warning: In the call to SQRT1, there is no actual argument corresponding to the dummy argument A.
x=sqrt1(2.0)
E:\fortran works\numeric1\test.f90(3) : Warning: Routine SQRT1 called with different number and/or type of actual arguments in earlier call - C attribute required if intended.
x=sqrt1(2.0)
test.obj - 0 error(s), 3 warning(s)
 楼主| 发表于 2010-3-25 21:44 | 显示全部楼层
已经自己解决了。加一个interface就可以了,贴出来给大家参考参考吧。
program main
interface
   real(8) a
      end function
end interface
complex(8) x
x=sqrt1(dble(2.0))
print *, x
end program main
   real(8) a
   parameter(N=1E8)
   logical::s=.false.
   x=abs(a)
   p=(x0+x/x0)/2
   do i=1,N
      q=(p+x/p)/2
      s=.true.
   exit
      else
         p=q
   endif
enddo
      sqrt=-1
   return
   endif
   if (a<0) then
       sqrt1=cmplx(0,q)
   else
       sqrt1=cmplx(q,0)
   endif
end function
GMT+8, 2025-6-20 22:33 , Processed in 0.073102 second(s), 18 queries , Gzip On.
