查看: 1936|回复: 0
[控制系统类] 求助,simulink仿真报错
发表于 2010-2-4 01:59 | 显示全部楼层 |阅读模式
两条报错:
1:An error occurred while propagating data type 'boolean' from 'tank/Fuzzy Logic  Controller  with Ruleviewer/Fuzzy Logic Controller/FIS Wizard/Defuzzification1/Zero Strength (COA)', output port 1
2:MinMax does not accept 'boolean' signals. The input and output signal(s) of 'tank/Fuzzy Logic  Controller  with Ruleviewer/Fuzzy Logic Controller/FIS Wizard/Defuzzification1/Max (COA)' must be one of the MATLAB 'uint8', 'uint16', 'uint32', 'int8', 'int16', 'int32', 'single', or 'double' data types, or one of the Fixed-point data types
谢谢高人指点啊!
GMT+8, 2025-8-11 11:15 , Processed in 0.064456 second(s), 18 queries , Gzip On.
