查看: 4093|回复: 3
[1stopt] 请问1stopt多峰拟合, 其中一个峰不出来怎么办?
发表于 2009-9-30 15:50 | 显示全部楼层 |阅读模式
我想用2个对数正态分布进行拟合, 应该属于多峰拟合
因为有物理意义, 所以希望n>0.
1stopt总是拟合不出来 最小的一个峰.
而origin中又只能对正态分布进行多峰拟合, 所以没有办法, 难道非得把对数正态转成正态分布, 再用origin拟合吗?
请大家帮帮我, 讨论一下, 至少分析一下思路, 知道下一步怎么努力
数据和拟合图如下
右边的小峰总是拟合不出来
公式如下:
数据如下:
Title "Type your title here";
Parameters a1,n1[1000,9E6],a2,n2[300,9E2],a3,r1,r2;
constant r1=128.61,r2=530;
//constant r1=33.71646,r2=138.671,r3=524.4044,n3=350.1;
Variable x,y;
Function y=(n1/(((2*pi)^0.5)*log(a1)*ln(10)))*exp(-((log(x/r1))^2)/(2*(log(a1))^2))+(n2/(((2*pi)^0.5)*log(a2)*ln(10)))*exp(-((log(x/r2))^2)/(2*(log(a2))^2));
Data;
10.36822        62.80889
11.14765        73.39486
11.99193        90.67867
12.90144        117.42344
13.88063        146.59585
14.93988        176.7792
16.07918        205.88632
17.30335        250.99153
18.62241        293.63164
20.04634        334.54949
21.58036        400.77184
23.23409        461.44556
25.02272        526.00254
26.95145        610.93688
29.03473        711.77863
31.28813        822.59267
33.71646        922.57109
36.34419        1036.4941
39.18725        1158.57488
42.25972        1273.83102
45.59681        1392.48298
49.20929        1530.51029
53.12084        1665.88128
57.36745        1776.49122
61.97835        1889.03784
66.99398        2033.36179
72.44435        2240.25929
78.3739                2435.4358
84.8427                2629.77248
91.91076        2803.08121
99.63332        2972.85904
108.0749        3118.05541
117.3346        3254.73975
127.4991        3367.56001
138.671                3447.14193
150.9866        3472.864
164.5896        3420.58855
179.6455        3264.883
196.3333        3078.74925
214.8871        2795.54887
235.5766        2537.93822
258.7154        2152.40878
284.6491        1764.68047
313.7942        1511.76268
346.6511        1101.53983
383.8011        758.23298
410.0                589.56088
425.915                487.09794
430.0                470.19655
440.0                428.82226
450.0                387.44798
460.0                346.0737
470.0                304.69941
473.7774                289.07069
480.0                306.78283
490.0                335.24704
500.0                363.71126
510.0                392.17547
520.0                   420.63968
530.0                422.66274
540.0                403.87348
550.0                385.08421
560.0                366.29495
574.4563                339.13263
580.0                330.50894
600.0                299.39727
620.0                268.2856
630.0                252.72977
648.074                224.61415
660.0                207.18925
680.0                177.96756
700.0                148.74587
720.0                119.52417
748.3315                78.12945
894.4272                32.0669
1095.445                7.11801
[ 本帖最后由 linzhenyi0 于 2009-9-30 20:33 编辑 ]
发表于 2009-9-30 16:55 | 显示全部楼层
下面两句有问题吧?
r1,r2被同时定义成了参数和常数。
发表于 2009-9-30 17:05 | 显示全部楼层
这个结果如何:
均方差(RMSE): 29.8882974041181
残差平方和(RSS): 67891.584450493
相关系数(R): 0.999623356417987
相关系数之平方(R^2): 0.999246854696363
决定系数(DC): 0.999244819778612
卡方系数(Chi-Square): 145.024370599821
F统计(F-Statistic): 11090.0679901415
参数 最佳估算
n1          62.3319839009691
a1          0.907569842362343
r1          438.187868272914
n2          -4628.98326902897
a2          0.425119579887233
r2          103.434173267256
n3          -1714.64432483643
a3          0.642614542531856
r3          165.848708911989
 楼主| 发表于 2009-9-30 18:12 | 显示全部楼层
首先非常谢谢dingd,
其实是出不来结果, 才被迫改成常值的, 我用的是1.5版本
能否再加入2个条件,
1) n>0?
因为拟合有物理意义, x表示直径, y表示浓度, n好像表示面积( 只能是好像了, 参数意义不清楚, (文献中从几百到几万),
2) 不要n3, a3, r3, 因为只 有2个峰, 对应2组参数,
GMT+8, 2025-7-28 09:21 , Processed in 0.061542 second(s), 24 queries , Gzip On.
