查看: 2238|回复: 0
[C/C++] 请版主帮我看看程序如何修改
发表于 2009-9-28 14:22 | 显示全部楼层 |阅读模式
一个编码器的数据采集程序,用VC调用VB编写的DLL出错。错误提示如下:
Test.cpp
C:\Documents and Settings\Owner.LENOVO-52CEDA01\桌面\Test.cpp(23) : error C2664: 'readGAM60Value' : cannot convert parameter 1 from 'char [9]' to 'unsigned short ** '
        Types pointed to are unrelated; conversion requires reinterpret_cast, C-style cast or function-style cast
Error executing cl.exe.
VB编写的DLL见附件。
程序代码:
#include <stdio.h>
// This is the path for your DLL.
// Make sure that you specify the exact path.
#import "d:\project1.dll"  no_namespace
void main()
       BSTR bstrDesc;
       try
            CoInitialize(NULL);
            // Declare the Interface Pointer for your Visual Basic object. here,
            // _Class1Ptr is the Smart pointer wrapper class representing the
            // default interface of the Visual Basic object.
            _Class1Ptr ptr;
            // Create an instance of your Visual Basic object, here
            // __uuidof(Class1) gets the CLSID of your Visual Basic object.
            ptr.CreateInstance(__uuidof(Class1));
            double jiaodu =ptr->readGAM60Value("2330300D");
      catch(_com_error &e)
      {            bstrDesc = e.Description();         }
      CoUninitialize();
[ 本帖最后由 li343 于 2009-9-28 14:25 编辑 ]
GMT+8, 2025-7-13 14:36 , Processed in 0.057825 second(s), 17 queries , Gzip On.
