查看: 1656|回复: 5
[CFD及热分析] 热点耦合分析出错!急求大家帮忙!
发表于 2009-6-6 10:50 | 显示全部楼层 |阅读模式
原来是一个热分析,现在的是热电耦合的,不收敛,请大家帮忙看看原因吧!感激不尽!
  1. Finish
  2. /clear
  3. /filname,redian,1
  4. /UNITS,MKS
  5. /PREP7
  6. ET,1,solid69
  7. ET,2,solid69
  8. MPTEMP,1,273,2500,5000,7500,10000,12500
  9. MPTEMP,7,15000,17500,20000
  10. MPDATA,RSVX,1,1,1000,100,1,1.3e-3,3.3e-4,1.6e-4
  11. MPDATA,RSVX,1,7,1.2e-4,9.8e-5,8.5e-5
  12. MPDATA,KXX,1,1,0,0.1,0.2,0.3,0.6,1.6
  13. MPDATA,KXX,1,7,2.4,2.0,2.2
  14. MPDATA,C,1,1,500,500,500,600,1250,6000
  15. MPDATA,C,1,7,10000,4000,2500
  16. MPDATA,DENS,1,1,1.1,0.2,0.1,0.07,0.04,0.03
  17. MPDATA,DENS,1,7,0.02,0.015,0.014
  18. !mp,KXX,2,,173
  19. !MP,RSVX,2,,0.0000000528
  20. MPTEMP,,,,,,,,
  21. MPTEMP,1,0
  22. MPDATA,KXX,2,,173
  23. MPTEMP,,,,,,,,
  24. MPTEMP,1,0
  25. MPDATA,RSVX,2,,0.0000000528
  26. !建模
  27. wpro,,-90
  28. CYL4,0,0,0.006,90, , ,0.006
  29. WPAVE,0,0.004,0
  30. CONE,0.00024,0.0014,0,0.002,0,90,
  31. VSBW,all,,dele!分割平面
  32. WPAVE,0,0,0
  33. CYL4,0,0,0.00024,90, , ,0.004
  34. CYL4,0,0,0.0014,90, , ,0.006
  35. CYL4,0,0,0.003,90, , ,0.006
  36. VOVLAP,all
  37. VGLUE,ALL
  38. AGLUE,ALL
  39. LGLUE,ALL
  40. !NUMMRG,NODE
  41. NUMCMP,all
  42. /VIEW,1,1,2,3
  43. WPCSYS,-1,0        !工作平面坐标归位
  44. WPSTYLE,,,,,,,,0
  45. !划分网格
  46. VSEL,,,,2    !分配钨极材料属性
  47. VATT,2,1,2
  48. vsel,inve    !选择其他所有的,分配气体材料属性
  49. VATT,1,1,1
  50. allsel,all
  51. AESIZE,7,0.0001,
  52. AESIZE,12,0.0001,
  53. AESIZE,18,0.0001,
  54. AESIZE,22,0.0002,
  55. AESIZE,26,0.0002,
  56. AESIZE,32,0.0002,
  57. AESIZE,34,0.0002,
  58. LESIZE,2, , ,16, , , , ,1
  59. MSHAPE,0,3d
  60. MSHKEY,1
  61. VMESH,all
  62. finish
  63. save
  64. /sol
  65. VSEL,S, , ,1
  66. VSEL,A, , ,4
  67. VSEL,A, , ,7
  68. TUNIF,10000,
  69. ALLSEL,ALL
  70. asel,s,,,2
  71. asel,a,,,9
  72. DA,all,TEMP,3000
  73. asel,s,,,5
  74. asel,a,,,6
  75. asel,a,,,25
  76. asel,a,,,33
  77. DA,all,TEMP,1000
  78. asel,s,loc,y,0
  79. DA,all,TEMP,5000
  80. DA,all,VOLT,0,0
  81. ASEL,S,AREA,,4
  82. NSLA,S,1
  83. CP,next,VOLT,ALL
  84. *GET,NMIN,NODE,,NUM,MIN
  85. F,NMIN,AMPS,-150
  86. ALLSEL,ALL
  87. solve
[ 本帖最后由 lilichunyan 于 2009-6-6 20:47 编辑 ]
发表于 2009-6-6 14:43 | 显示全部楼层
ALLSEL,ALL
asel,s,,,2
asel,a,,,9
DA,all,TEMP,3000
asel,s,,,5
asel,a,,,6
asel,a,,,25
asel,a,,,33
DA,all,TEMP,1000
asel,s,loc,y,0
DA,all,TEMP,5000
是否应该在每次asel,s,..之前增加一个allsel,all
发表于 2009-6-6 15:19 | 显示全部楼层
"VSEL,S, , ,1
VSEL,A, , ,4
VSEL,A, , ,7
TUNIF,10000,
ALLSEL,ALL "
1。tunif命令为整个模型施加初始温度,所以选择命令无效
2。你的命令流我执行并收敛了,附件为计算结果。
3。根据ANSYS HELP,SOLID70单元的材料特性为
Material Properties KXX, KYY, KZZ, DENS, C, ENTH, VISC, MU (VISC and MU used only if KEYOPT(7) = 1. Do not use ENTH with KEYOPT(8) = 1).
[ 本帖最后由 jxxansys 于 2009-6-6 15:28 编辑 ]
结果图形
结果图形
 楼主| 发表于 2009-6-6 19:50 | 显示全部楼层
回复 沙发 16443 的帖子
这个倒是不用,我试过!
 楼主| 发表于 2009-6-6 19:55 | 显示全部楼层
回复 板凳 jxxansys 的帖子
呵呵,还真收敛了,发帖的时候稍微改了一下,但只是去掉的没用的啊!呵呵,很奇怪!
但是这个结果是不对的,那我怎么能为部分区域加上初始温度10000啊?
 楼主| 发表于 2009-6-6 20:52 | 显示全部楼层
回复 板凳 jxxansys 的帖子
原来的程序是我把热电部分分开了,现在是整个程序,不收敛的,您看看会不会?
GMT+8, 2025-1-12 05:55 , Processed in 0.074674 second(s), 22 queries , Gzip On.
