查看: 3712|回复: 4
[共享资源] 求MATLAB freqz_m函数的源码
发表于 2009-5-30 23:52 | 显示全部楼层 |阅读模式
百度Google都搜不到,好不容易找到个还要付费,拜托各位有的发个源码:lol 谢谢:loveliness:
发表于 2009-5-31 00:01 | 显示全部楼层
搜寻一下matlab路径, 不就有freqz.m !?
发表于 2009-5-31 07:59 | 显示全部楼层
回复 楼主 dongchao1207 的帖子
  1. which freqz.m
发表于 2009-5-31 11:47 | 显示全部楼层
可能楼主需要的 freqz_m.m,这个其实是能搜到的。
  1. function [db,mag,pha,grd,w] = freqz_m(b,a);
  2. % Modified version of freqz subroutine
  3. % ------------------------------------
  4. % [db,mag,pha,grd,w] = freqz_m(b,a);
  5. %  db = Relative magnitude in dB computed over 0 to pi radians
  6. % mag = absolute magnitude computed over 0 to pi radians
  7. % pha = Phase response in radians over 0 to pi radians
  8. % grd = Group delay over 0 to pi radians
  9. %   w = 501 frequency samples between 0 to pi radians
  10. %   b = numerator polynomial of H(z)   (for FIR: b=h)
  11. %   a = denominator polynomial of H(z) (for FIR: a=[1])
  12. %
  13. [H,w] = freqz(b,a,1000,'whole');
  14.     H = (H(1:1:501))'; w = (w(1:1:501))';
  15.   mag = abs(H);
  16.    db = 20*log10((mag+eps)/max(mag));
  17.   pha = angle(H);
  18. %  pha = unwrap(angle(H));
  19.   grd = grpdelay(b,a,w);
  20. %  grd = diff(pha);
  21. %  grd = [grd(1) grd];
  22. %  grd = [0 grd(1:1:500); grd; grd(2:1:501) 0];
  23. %  grd = median(grd)*500/pi;
 楼主| 发表于 2009-6-1 14:43 | 显示全部楼层
回复 地板 friendchj 的帖子
就是这个,谢谢:loveliness: 我搜到的都要money才让下:@L
GMT+8, 2024-10-1 05:31 , Processed in 0.066072 second(s), 22 queries , Gzip On.
