查看: 4095|回复: 2
[Hyperworks] ERROR # 153
发表于 2009-5-18 18:41 | 显示全部楼层 |阅读模式
大家好,这个错误怎么解决啊?
 楼主| 发表于 2009-5-18 18:41 | 显示全部楼层
**                         OptiStruct 8.0SR1                          **
**          Finite Element and Multi-body Dynamics Analysis           **
**                     and Optimization Software                      **
**                   from Altair Engineering, Inc.                    **
**           Windows XP Professional  SP2 (Build 2600)  FMG           **
**      2 CPU:  Intel(R) Pentium(R) Dual  CPU  E2180  @ 2.00GHz       **
**                        CPU speed  2000 MHz                         **
**                     1386 MB RAM,  3424 MB swap                     **
** Build tag: 0360770_4401OR1_Ci3242M-000             14000           **
**  COPYRIGHT (C) 1996-2007                 Altair Engineering, Inc.  **
** All Rights Reserved.  Copyright notice does not imply publication. **
** Contains trade secrets of Altair Engineering, Inc.                 **
** Decompilation or disassembly of this software strictly prohibited. **
*** OptiStruct defaults set from:
   install config file: D:\Altair\hw8.0sr1/optistruct/optistruct.cfg
WARNING # 1198
  PSHELL with T=blank (field 4): thickness must be
  specified on all elements using this property (using fields T1..T4).
   Detected while reading line 51723 from file
     D:/00fmg_save/fmg_o/fmg0002.fem:
  "PSHELL        55       1               1               1        0.0"
WARNING # 1198
   Detected while reading line 51726 from file
  "PSHELL        63       1               1               1        0.0"
OPTIMIZATION FILE AND PARAMETER INFORMATION :
  Optimization parameters from : D:/00fmg_save/fmg_o/fmg0002.fem
  FEM model file               : D:/00fmg_save/fmg_o/fmg0002.fem
  Output files prefix          : D:/00fmg_save/fmg_o/fmg0002
FINITE ELEMENT MODEL DATA INFORMATION :
  Total # of Nodes                     :    26211
  Total # of Elements                  :    25451
  Total # of Rigid Elements            :        5
  Total # of Rigid Element Constraints :       30
  Total # of Degrees of Freedom        :   154602
  Total # of Non-zero Stiffness Terms  :  4164255
  Element Type Information
   CQUAD4   Elements   :    25358
   CTRIA3   Elements   :       93
  Load and Boundary Information
   FORCE Sets        :        1
   SPC   Sets        :        1
  Material and Property Information
   PSHELL Cards      :        2
   MAT1   Cards      :        1
OPTIMIZATION PROBLEM PARAMETERS :
NO DESIGN MATERIAL OR DESIGN VARIABLES FOUND  : ANALYSIS ONLY
   Load Subcase Summary :
   Subcase ID    SPC ID   FORCE ID  Weight = w(i)
          1            1         2           1.000
   Design Parameters Summary :
   Run Type                        :   Analysis Only
   Scratch file directory          : ./
                                     Free space:   3518 MB
   Number of CPU processors        :         1
MEMORY ESTIMATION INFORMATION :
Solver Type is:  Sparse-Matrix Solver
Current Memory (RAM)                                    :      97 MB
Estimated Minimum Memory (RAM) for Out of Core Solution :      87 MB
Recommended Memory (RAM) for Out of Core Solution       :      97 MB
Recommended Memory (RAM) for In-Core Solution           :     390 MB
DISK SPACE ESTIMATION INFORMATION :
Estimated Disk Space for Output Data Files              :      14 MB
Estimated Scratch Disk Space for In-Core Solution       :      87 MB
Estimated Scratch Disk Space for Out of Core Solution   :     472 MB
BEGINNING ANALYSIS SOLUTION ....
ANALYSIS RESULTS :
ITERATION   0
          Auto-SPC d. o. f.s for loadcase        1
          Number of Auto-SPC d. o. f.s  =   154542
            Grid No.       Component
               50138       1 2 3 4 5 6
               50139       1 2 3 4 5 6
               50140       1 2 3 4 5 6
               50141       1 2 3 4 5 6
               50142       1 2 3 4 5 6
               50143       1 2 3 4 5 6
               50144       1 2 3 4 5 6
               50145       1 2 3 4 5 6
               50146       1 2 3 4 5 6
               50147       1 2 3 4 5 6
               50148       1 2 3 4 5 6
               50149       1 2 3 4 5 6
               52862       1 2 3 4 5 6
               52863       1 2 3 4 5 6
               52864       1 2 3 4 5 6
               52865       1 2 3 4 5 6
               52866       1 2 3 4 5 6
            By default, Auto-SPC printing is limited to 100 dofs.
ERROR #     153 FROM SUBROUTINE statslv
Exactly zero pivoting encountered during Numerical Factorization;
the model may have rigid body mode.
  Solver error no. =       -503
        spc set id =          1
             index =          1
Possible reasons are:
1) insufficiently constrained model,
2) having rigid body mechanisms within the model,
3) extremely ill-conditioned rigid element sets,
4) extremely thin shells (as used for  "skinning") that have MID2/MID3,
5) gap elements with extremely high stiffness (KA, especially KT or MU).
Check the model and rerun the problem.
(osdiag,46,1 may be used to find the rigid body modes.  To do so,
  change the input to be an eigenvalue analysis and add osdiag,46,1.)
(WARNING: results obtained with osdiag,46,1 cannot be used because
           the model is changed internally.)
                         ***** FATAL SOLVER ERROR *****
This error occurs in subroutine slvdrv
                      ***** FATAL ERROR ENCOUNTERED *****
RESOURCE USAGE INFORMATION
MAXIMUM MEMORY USED                                        97 MB
MAXIMUM DISK SPACE USED                                     0 MB
COMPUTE TIME INFORMATION
EXECUTION STARTED                         Mon May 18 18:31:14 2009
EXECUTION COMPLETED                       Mon May 18 18:31:41 2009
ELAPSED TIME                                         00:00:27
CPU TIME                                             00:00:13
                            ***** END OF REPORT *****
For Useful OptiStruct Tips and Tricks, go to the URL:
http://www.altair.com/support/tips/tip_os.htm
  OptiStruct ERROR: 153
发表于 2009-7-30 05:47 | 显示全部楼层
        spc set id =          1
             index =          1
GMT+8, 2025-7-11 08:40 , Processed in 0.057386 second(s), 19 queries , Gzip On.
