查看: 1835|回复: 2
job提交时出现的问题,请高人指点
发表于 2009-5-14 11:40 | 显示全部楼层 |阅读模式
是error中的说明(如下),不知道是什么原因,请问该怎么处理
ABAQUS Error: The executable E:\abaqus\6.6-3\exec\standard.exe
aborted with system error code 142.
Please check the .dat, .msg, and .sta files for error messages if the files
exist.  If there are no error messages and you cannot resolve the problem,
please run the command "abaqus job=support information=support" to report and
save your system information.  Use the same command to run ABAQUS that you
used when the problem occurred.  Please contact your local ABAQUS support
office and send them the input file, the file support.log which you just
created, the executable name, and the error code.
ABAQUS/Analysis exited with errors
发表于 2009-5-14 14:18 | 显示全部楼层
这个问题既常见又复杂,一般是模型有问题,查查材料定义,接触什么的。尽量用GUI支持的关键字定义等等。另外,你的版本很老,可以考虑换一个,说不定问题就没有了
[ 本帖最后由 ydliu_zn 于 2009-5-14 14:19 编辑 ]
 楼主| 发表于 2009-5-15 09:19 | 显示全部楼层
谢谢,我试试看
GMT+8, 2025-1-12 22:55 , Processed in 0.061411 second(s), 18 queries , Gzip On.
