查看: 1768|回复: 0
job提交时出现的问题,请高人指点
发表于 2009-5-14 11:39 | 显示全部楼层 |阅读模式
是error中的说明(如下),不知道是什么原因,请问该怎么处理
ABAQUS Error: The executable E:\abaqus\6.6-3\exec\standard.exe
aborted with system error code 142.
Please check the .dat, .msg, and .sta files for error messages if the files
exist.  If there are no error messages and you cannot resolve the problem,
please run the command "abaqus job=support information=support" to report and
save your system information.  Use the same command to run ABAQUS that you
used when the problem occurred.  Please contact your local ABAQUS support
office and send them the input file, the file support.log which you just
created, the executable name, and the error code.
ABAQUS/Analysis exited with errors
GMT+8, 2025-7-30 18:30 , Processed in 0.096496 second(s), 18 queries , Gzip On.
