查看: 5500|回复: 9
[绘图技巧] PlotAxisAtOrigin
发表于 2009-3-26 09:00 | 显示全部楼层 |阅读模式
来自:http://blogs.mathworks.com
As an application engineer I showed MATLAB to a lot of people. Occasionally when I presented graphics capabilities someone would ask how to make plots where the X and Y axes lines go through the origin. You know: the way we learned to draw them in school. By default MATLAB puts the X axes on bottom and the Y axes on the left.
  1. x = -2*pi:pi/10:2*pi;
  2. y = sin(x);
  3. plot(x,y)
While the xAxisLocation can be set to top, and the yAxisLocation can be right, neither has an origin option for example. So, instead, I usually suggested drawing lines through the origin. In fact, prior "Pick of the Week" star Brandon Kuczenski made that trivial with hline and vline.
  1. hline(0)
  2. vline(0)
Not satisfied? Neither was Shanrong. Hence, PlotAxisAtOrigin.
  1. PlotAxisAtOrigin(x,y)
代码: hline.m (3.03 KB, 下载次数: 57)
vline.m (2.97 KB, 下载次数: 47)
PlotAxisAtOrigin.m (1003 Bytes, 下载次数: 86)
发表于 2009-3-26 18:53 | 显示全部楼层
第一时间感觉似成相识, 刚刚有空找了下, 原来在官网!
而且本版亦多次讨论过, 可能楼主没见到! 还是感谢楼主的热心!
http://www.mathworks.com/matlabcentral/fileexchange/10473
如何改变坐标轴的位置?
http://forum.vibunion.com/forum/ ... =%D7%F8%B1%EA%D6%E1
请问matlab画二维图时,是否可以显示坐标轴的箭头?
 楼主| 发表于 2009-3-27 08:30 | 显示全部楼层
在这里没看见过,呵呵。而且我帖子已经注明出处了。
由于作图需要在官网找到,顺便就贴出来了。为了大家方便。
发表于 2009-3-27 15:09 | 显示全部楼层
回复 板凳 16443 的帖子
LZ别误会! 我有看到注明出处, 这是非常负责的态度, 钦佩!
借宝地列出连接主要是希望有一完整性
 楼主| 发表于 2009-3-27 19:26 | 显示全部楼层
我没什么误会的,呵呵。
您多心了。
发表于 2011-3-4 15:23 | 显示全部楼层
谢谢,但是就是看不了啊
发表于 2011-3-4 21:33 | 显示全部楼层
回复 6 # shijuyi 的帖子
什么叫“看不了”?
发表于 2011-6-24 10:35 | 显示全部楼层
感谢楼主,好东西
发表于 2012-1-6 15:10 | 显示全部楼层
thx for sharing
发表于 2013-1-10 15:03 | 显示全部楼层
谢谢分享 对我很有用
GMT+8, 2024-11-17 17:56 , Processed in 0.073112 second(s), 26 queries , Gzip On.
