查看: 1437|回复: 3
[综合讨论] 新手请教 遗传算法的求解!!请高手帮忙!!
发表于 2009-3-23 17:32 | 显示全部楼层 |阅读模式
function[sol,eval]=gademo1eval(sol,options)
x=solve(1)
eval=x+10*sin(5*x)+7*cos(4*x);
clc
fplot('x+10*sin(5*x)+7*cos(4*x)',[0 9])
initPop=initializega(10,[1 9],'gademoleval');
plot(initPop(:,1),initPop(:,2),'b*')
[x endPop]=ga([0 9],'gademoleval',[],initPop,[le-5 1 1],'maxGenTerm',1,'normGeomSelect',[0.08],[arithXover'],[20],'nonUnifMutation',[2 1 3]);
plot(endPop(:,1),endPop(:,2),'bo')
[x endPop bpop trace]=ga([0 9],'gademoleval',[],initPop,[le-6 1 1],'maxGenTerm',25,'normGeomSelect',[0.08],[arithXover'],[2],'nonUnifMutation',[2 25 3]);
plot (endPop(:,1),endPop(:,2),'y*')
figure(2)
plot(trace(:,1),trace(:,3),'y-')
hold on
plot(trace(:,1),trace(:,2),'r-')
xlabel('Generation');ylabel('Fittness');
legend
问题:
??? Error using ==> eval
Undefined command/function 'gademoleval'.
Error in ==> initializega at 80
  eval(estr);
Error in ==> gademo1 at 6
 楼主| 发表于 2009-3-23 19:02 | 显示全部楼层
帮帮忙啊!
Error in ==> initializega at 49
if any(evalFN<48) %Not a .m file
function [pop] = initializega(num, bounds, evalFN,evalOps,options)
if nargin<5
  options=[1e-6 1];
if nargin<4
  evalOps=[];
  if options(2)==1 %Float GA
    estr=['x=pop(i,1); pop(i,xZomeLength)=', evalFN ';'];
  else %Binary GA
    estr=['x=b2f(pop(i,:),bounds,bits); pop(i,xZomeLength)=', evalFN ';'];
else %A .m file
    estr=['[ pop(i,:) pop(i,xZomeLength)]=' evalFN '(pop(i,:),[0 evalOps]);'];
  else %Binary GA
    estr=['x=b2f(pop(i,:),bounds,bits);[x v]=' evalFN ...
'(x,[0 evalOps]); pop(i,:)=[f2b(x,bounds,bits) v];'];
numVars     = size(bounds,1);   %Number of variables
rng         = (bounds(:,2)-bounds(:,1))'; %The variable ranges'
  xZomeLength = numVars+1;   %Length of string is numVar + fit
  pop         = zeros(num,xZomeLength);  %Allocate the new population
  pop(:,1:numVars)=(ones(num,1)*rng).*(rand(num,numVars))+...
    (ones(num,1)*bounds(:,1)');
else %Binary GA
  bits=calcbits(bounds,options(1));
  xZomeLength = sum(bits)+1;   %Length of string is numVar + fit
  pop = round(rand(num,sum(bits)+1));
for i=1:num
  eval(estr);
发表于 2009-3-23 22:47 | 显示全部楼层
ga没学过, 刚刚help下 (r2006a)
x = ga(fitnessfcn,nvars,A,b,Aeq,beq,LB,UB,nonlcon,options)
好像与楼主调用方式不同!?
发表于 2009-3-24 10:23 | 显示全部楼层
调用格式出错
GMT+8, 2024-10-1 15:11 , Processed in 0.053289 second(s), 17 queries , Gzip On.
