查看: 1898|回复: 0
[C/C++] 请帮我把这个程序改成C#的
发表于 2009-3-23 08:06 | 显示全部楼层 |阅读模式
//求解任意一元三次方程 a*x^3+b*x^2+c*x+d=0
//输入a,b,c,d;  输出三个解分别为x1,x2,x3
#include  <complex>
#include  <iostream>
#include  <math.h>
using   namespace   std;
void  quadratic_equation(double a4,double b4,double c4,complex<double> &z1,complex<double> &z2);
int main()
float a,b,c,d;
double p,q,delta;
double M,N;
complex<double> temp1,temp2;
complex<double> x1,x2,x3;
complex<double> y1,y2;
cout<<" please input the coefficients a, b, c, d : ";
cin>>a>>b>>c>>d;
//输入一元三次方的系数,得方程为a*x^3+b*x^2+c*x+d=0;
if(a==0)
  quadratic_equation(b,c,d,y1,y2);
  x1 = y1;
  x2 = y2;
  x3 = 0;
  std::cout<<" x1="<< x1 <<endl;
  std::cout<<" x2="<< x2 <<endl;
  std::cout<<" x3="<< x3 <<endl;
else
p = -1.0/3*pow((b*1.0/a),2.0)+c*1.0/a;
    q = 2.0/27*pow((b*1.0/a),3.0)-1.0/3*b*c/(a*a)+d*1.0/a;
// p = -1/3*(b/a)^2+c/a;
// q = 2/27*(b/a)^3-1/3*b*c/(a*a)+d/a;
//化成 y^3+p*y+q=0 形式
delta = pow((q/2.0),2.0)+pow((p/3.0),3.0);
    //判别式 delta = (q/2)^2+(p/3)^3;
cout<<" delta>0,有一个实根和两个复根;delta=0,有三个实根;delta<0,有三个不等的实根"<<endl;
    cout<<" 判别式的值 delta="<<delta<<endl;
//delta>0,有一个实根和两个复根;
//delta=0,有三个实根;
    //delta<0,有三个不等的实根。
    complex<double>  omega1(-1.0/2, sqrt(3.0)/2.0);
complex<double>  omega2(-1.0/2, -sqrt(3.0)/2.0);
complex<double>  yy(b/(3.0*a),0.0);
    M = -q/2.0;
if(delta<0)
   N = sqrt(fabs(delta));
         complex<double>  s1(M,N);
         complex<double>  s2(M,-N);
   x1 = (pow(s1,(1.0/3))+pow(s2,(1.0/3)))-yy;
   x2 = (pow(s1,(1.0/3))*omega1+pow(s2,(1.0/3))*omega2)-yy;
   x3 = (pow(s1,(1.0/3))*omega2+pow(s2,(1.0/3))*omega1)-yy;
  //输出结果 x1=y1-b/(3*a); x2=y2-b/(3*a); x3=y3-b/(3*a);
else
  N = sqrt(delta);
  //cout<<" please output the M+N="<<M+N<<endl;
  //cout<<" please output the M-N="<<M-N<<endl;
  //  M+N= -q/2+sqrt((q/2)^2+(p/3)^3);
  //  M-N= -q/2-sqrt((q/2)^2+(p/3)^3);
  complex<double>  f1(M+N,0);
  complex<double>  f2(M-N,0);
   if(M+N >= 0)
       temp1 = pow((f1),1.0/3);
   else
    temp1 = -norm(pow(sqrt(f1),1.0/3));
   if(M-N >= 0)
    temp2 = pow((f2),1.0/3);
   else
    temp2 = -norm(pow(sqrt(f2),1.0/3));
   x1 = temp1+temp2-yy;
         x2 = omega1*temp1+omega2*temp2-yy;
         x3 = omega2*temp1+omega1*temp2-yy;
  return 0;
double delta;
delta=b4*b4-4*a4*c4;
complex<double> temp(delta,0);
    temp1 = (-b4)/(2*a4);
temp2 = sqrt(temp)/(2*a4);
z1=temp1+temp2;
z2=temp1-temp2;
GMT+8, 2025-7-15 09:16 , Processed in 0.063796 second(s), 18 queries , Gzip On.
