查看: 1163|回复: 2
[编程技巧] 帮忙检查下程序,有个循环不能执行
发表于 2009-3-11 15:35 | 显示全部楼层 |阅读模式
%function Mredsim=n_Mm(Jredsim)
%Set initial "gemesste Strom"
Im = [151.0348  139.0837  119.3383  105.8283  90.7595  85.5633  79.8475   78.2887  82.6188...
       82.4456   82.4456   83.6581   85.9097  85.9097  115.1814 139.0837 143.4138 148.0903...
       133.7143  117.4330  107.9068  106.0015 116.0474  43.3013  46.7654  344.3317 146.5315...
       146.5315   80.5404   80.5404  80.7136  80.7136 137.3516  132.3287   90.4131  75.1710...
       72.5729   75.8638   78.2887   78.2887 161.2539  164.3716  162.9860  138.5641 144.7994...
       158.1362  166.6233  166.7965 213.7351 192.0844  140.6425  108.0800  90.2398   80.7136...
       82.0992   91.4523   103.5766 105.6551 105.8283  104.4427  111.8905  51.9615   49.1902...
       403.0482 400.4501  161.7735  161.7735  106.8675  188.9667  229.8431  231.4020 231.4020...
      177.7084  156.9238  142.3746   25.9808   69.2820  402.5286  401.3162  333.9394 321.4686...
      310.7299  258.5952  200.9179  200.9179  124.3612  109.8120  95.4360   91.4523   91.6255...
      104.2695  122.9756  126.2665  150.8616  167.6625  169.5678  153.1133  139.6033 127.3057...
      125.7469  112.0637  126.0933  183.5974  200.9179  213.0422  251.6670  216.3331  216.3331...
      119.5115  112.0637  109.4656  110.3316  116.7402  115.8742  106.5211  103.9230   96.4752...
      97.5145    99.0733  104.0963  106.1747  110.6780  103.9230  100.4589   90.7595   87.8150...
      86.4293   86.0829   86.2561   86.4293   86.4293   86.2561   85.2169   79.8475   79.8475...
      77.7691   78.9815   80.8868   82.6188   82.4456   81.5796   78.9815   78.8083   80.7136...
      81.4064   81.2332   80.8868   80.7136   79.8475   80.1940   82.4456   82.7920   83.4848...
      85.5633   87.6418   90.7595   93.3575   93.8772   93.5307   93.0111   92.4915   91.7987...
      91.6255   89.5470   89.7202   89.8934   89.8934   89.7202   89.7202   89.7202   89.5470...
      89.3738   88.8542   88.8542   89.0274   89.3738   92.6647   92.1451   91.4523   90.7595...
     87.2954   87.1222   87.1222   87.2954   87.4686   87.6418    87.6418   87.9882   87.9882...
     88.5078   88.8542   89.2006   89.0274   89.0274   99.2465  111.8905  112.5833   122.4560...
     122.2828  111.8905  109.6388   95.4360   86.0829   84.1777   83.4848   84.0045   84.8705...
     92.1451   91.2791   91.1059   91.9719  104.2695  130.9430  168.3553  170.4338  183.2510...
     191.9112  260.0000  291.5042  291.5042  236.4249  198.4930  198.4930  122.4560   87.2954...
     83.1384   81.9260   92.8379  107.3872  115.7010   111.7173  101.1518   89.5470   86.4293...
     81.2332   80.8868   80.8868   81.5796   93.5307   95.4360  103.9230   106.0015  107.3872...
     113.6225  116.0474  130.4234  165.4109  177.8816  194.1629  223.2613  223.7810  207.1533...
     204.3820  170.2606  150.5152  138.9105  127.3057  114.3154  100.1125   97.3413   90.9327...
     92.4915  104.4427   138.5641  152.5937  154.6721  159.3487  141.5086  123.6684  124.5345 ...
     170.9534  188.7935  204.7284  213.3887  183.2510  148.2635   94.0504   79.6743   73.9586...
     79.3279   93.1843   91.9719   91.4523   90.2398   81.7528   80.3672   65.8179   25.9808...
     29.4449  273.1444  308.3050  283.5367   69.4552   74.8246   74.6514   79.5011   83.3116...
     85.3901   81.9260   73.7854   72.2265   72.2265   73.4390   75.1710   77.5959   77.4227...
     75.5174   74.1318   73.6122   73.2657   73.2657   73.9586   74.3050   74.8246   74.6514...
     74.4782   73.9586   73.9586   73.9586   73.9586   73.9586   74.1318   74.1318   74.1318...
     74.1318   74.1318   74.1318];
%Drehnzahl rechnen
S=sqrt(65.02759421^2-4*(-0.02463815532)*(-42058.38932-Im));
nm=(-65.02759421-S)./(2*(-0.02463815532));
%Differenzial Gleichung rechnen
Jred=195;
Jredsim=input('enter the number of Jredsim : ');
tm=1:326;
dt=1;
%Mit formel Mred und Mredsim ausrechne
Mm= polyval([4.906818140e-007, - 0.003522870493, 8.928126016, - 9.675323630e+003, 3.830301399e+006],nm);
Mred=Mm(1:326)-(abs(diff(nm))*2*pi*Jred/60);
%Mredsim ausrechnen
n_e=zeros(1,size(nm(1:326),2));
Mm_e=zeros(1,size(nm(1:326),2));
for i=1:size(nm(1:326),2)
    if i==1
        n0=nm(i);
        Mm_e(i)=polyval([4.906818140e-07,-0.003522870493,8.928126016,-9.675323630e+003,3.830301399e+006],n0);
        sn=(Mm_e(i)-Mred(i))*dt/(2*pi*Jredsim);
        n_e(i)=n0+sn;
    else
        Mm_e(i)=polyval([4.906818140e-07,-0.003522870493,8.928126016,-9.675323630e+003,3.830301399e+006],n_e(i-1));
        n_e(i)=nm(i)+sn;
%Plot Motormoment-Mm,drehnzahl-n,reduziere Motormoment-Mred und reduziere simulink Motormoment-Mred
[AX,H1,H2]=plotyy(tm,[Mm(1:326);Mred],tm,[nm(1:326);n_e]);
ylim(AX(1),[-1000 1550]);
ylim(AX(2),[1450 1510]);
%xlim(AX(1),[0 330]);
%xlim(AX(2),[0 330]);
set(AX,'XTick',[0:10:330]);
set(AX(1),'YTick',[-1000:85:1550]);
set(AX(2),'YTick',[1450:2:1510]);
set(get(AX(1),'ylabel'),'String','Mm (t)','color','b','FontSize',14);
set(get(AX(2),'ylabel'),'String','nm(t)','color','r','FontSize',14);
set(H1(1),'LineStyle','-','color','b');
set(H1(2),'LineStyle','-','color','k');
set(H2(1),'LineStyle','-','color','r');
set(H2(2),'LineStyle','-','color','g');
box off;
title('Momentreduziert und Drehzahl','FontSize',16);
xlabel('t ','FontSize',14);
legend(H1,{'Mm','Mred(t)'},2)
legend(H2,{'nm','nredsim(t)'},1)
grid on;
在这个程序中的for和if循环语句不起作用,这是为什么?无论Jredsim是什么值,所显示出来的图都是一样的
哪位大大 能帮忙,当Jredsim输入不同的值的时候所得到的n_e应该是不同于nm的,而且很明显,但这个程序显示的不是这样
[ 本帖最后由 tianyi11911 于 2009-3-11 15:37 编辑 ]
发表于 2009-3-12 16:28 | 显示全部楼层
LZ的程序真的太长了, 可能很少人愿意看!
"无论Jredsim是什么值,所显示出来的图都是一样的!", 那很正常嘛!
n_e与nm基本上差个sn (n_e(i)=nm(i)+sn), 而sn=(Mm_e(i)-Mred(i))*dt/(2*pi*Jredsim), 当Mm_e与Mred很接近且Jredsim值较大时, sn非常小, 与nm差好几量级!
LZ可以Jredsim取10及100, 并在程序增加两行比较便知
figure; plotyy(tm,Mm(1:326),tm,Mred)
figure; plotyy(tm,nm(1:326),tm,n_e)
[ 本帖最后由 ChaChing 于 2009-3-12 16:33 编辑 ]
 楼主| 发表于 2009-3-13 17:46 | 显示全部楼层
谢谢主任,主任真是太好了,我的问题基本都是您给出的答复,非常感谢。
这个问题我用Excel做了一下 ,还是有很大差距的,但在matlab里差距就不大,所以就搞不明白了。
我再用您给的句子对比一下吧。谢谢
[ 本帖最后由 tianyi11911 于 2009-3-13 17:54 编辑 ]
GMT+8, 2024-10-1 15:11 , Processed in 0.056544 second(s), 18 queries , Gzip On.
