查看: 980|回复: 1
[综合讨论] shell93单元
发表于 2009-3-3 21:55 | 显示全部楼层 |阅读模式
在ansys命令流中:
R,1,t1
其中的1代表什么意思?
我使用的是shell93单元,t代表的是厚度,我想使用两个shell(板),第一个厚度是t1,第二个厚度是t2,那么如何用命令流表示?
A:
R,1,t1
R,1,t2
B:
R,1,t1
R,2,t2
发表于 2009-3-4 08:50 | 显示全部楼层
采用你的B方式就可以。
R, NSET, R1, R2, R3, R4, R5, R6
Defines the element real constants.
NSET
Set identification number (arbitrary). If same as a previous set number, set is redefined. Set number relates to that defined with the element [REAL]. Note that the GUI automatically sets this value.
R1, R2, R3, . . . , R6
Real constant values (interpreted as area, moment of inertia, thickness, etc., as required for the particular element type using this set), or table names for tabular input of boundary conditions. Use RMORE command if more than six real constants per set are to be input.
GMT+8, 2024-10-1 23:37 , Processed in 0.052313 second(s), 18 queries , Gzip On.
