查看: 2088|回复: 1
[ADAMS专区] 求助:运行仿真出错
发表于 2009-2-18 17:34 | 显示全部楼层 |阅读模式
运行仿真出错,提示如下:
WARNING:    The symbolic refactorization failed.  The matrix is structurally singular
   at time = 3.0.
WARNING:    ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
   NOTE:  The set of redundant constraints has changed at time = 3.0.
   at time = 3.0.
ERROR:      The simulation is terminating at time = 3.0.
   ADAMS can not solve the equations of motion because the mechanism has
   "locked up."    At least one constraint  can  no longer be satisfied.
   ADAMS is unable to satisfy the constraint for: JOINT testrig_1.JOINT_22 .
ERROR:   Lockup detected
盼高手赐教!!!!
发表于 2009-2-25 18:19 | 显示全部楼层
可以试试改求解器,如果是用的默认求解器的话,可以将I3换成SI2或S11
GMT+8, 2025-1-13 03:17 , Processed in 0.100202 second(s), 18 queries , Gzip On.
