查看: 2150|回复: 3
[案例分析] 转子动平衡案例分析
发表于 2009-2-18 16:17 | 显示全部楼层 |阅读模式
Analysis for the 1 octave frequency problem
今有一电机存在振动大问题,遭到客户投诉。所以退回来进行分析,找出原因,然后解决。
Motor information:Pole #: 2 voltage: 115V, RPM: 3600
1.
Put the motor into the anechoic room to test the vibration.
2.
Test the vertical and horizontal direction vibration of DE of motor with the B&K software(PLUSE)
3.
The result are as following:
Acc(m/s2)(RMS)
Vel(mm/s)(RMS)
Dis(μm)(RMS)
V
H
V
H
V
H
4# motor( do the dynamic balance)
0.966
0.952
0.465
0.894
2.702
2.849
4# motor
5.251
4.985
13.312
12.885
35.473
34.283
These below two Figs are the auto spectrum of vibration for motors, from the Figs, you can see that the vibration values is so big at 60.156Hz which is the first octave frequency, it also usually is called the rotate frequency. So we can diagnose the vibration problem whose reason is the dynamic balance for motor.
4.
So we do the dynamic balance for the motor. After that, we retest the vibration for the motor. The result as following:
[ 本帖最后由 jinfengshi_2005 于 2009-2-18 16:20 编辑 ]
案例分析.doc
55 KB, 下载次数: 106
发表于 2009-2-18 17:33 | 显示全部楼层
平衡后振动变小的数据干嘛要放在第三步呢?那不是分析过程中吗?
发表于 2016-1-26 20:43 | 显示全部楼层
学习下案例,
发表于 2016-1-26 21:08 来自手机 | 显示全部楼层
学习一下
GMT+8, 2025-1-13 02:52 , Processed in 0.086995 second(s), 24 queries , Gzip On.
