查看: 4935|回复: 4
[综合讨论] 求助,ANSYS用间接法进行焊接热应力分析中,SOLID70对应的单元到底是哪个哦?
发表于 2009-1-11 21:37 | 显示全部楼层 |阅读模式
求助,ANSYS用间接法进行焊接热应力分析中,ETCHG,命令中SOLID70对应的是SOLID45,怎么在运行中转化成了SOLID185来进行运算了呢??急,请各位大侠出手相救
发表于 2009-2-14 09:54 | 显示全部楼层
ansys 10这前版本solide70 etchg,tts后转为solid45,自ansys11 转为solid185,注意ansys帮助中etchg说明的所作的已作改变,市面上教材多数未变过来
发表于 2009-2-14 09:57 | 显示全部楼层
看ansys11帮助文件,solid45正被solid185取代
Release 11.0 Documentation for ANSYS
Commands Reference | E Commands |
ETCHG, Cnv
Changes element types to their corresponding types.
PREP7: Element Type
MP ME ST PR PRN <> <> FL EM EH <> PP <>
Cnv
Converts the element types to the corresponding type. Valid labels are:
ETI  —  Explicit to Implicit
ITE  —  Implicit to Explicit
TTE  —  Thermal to Explicit
TTS  —  Thermal to Structural
STT  —  Structural to Thermal
MTT  —  Magnetic to Thermal
FTS  —  Fluid to Structural
ETS  —  Electrical to Structural
Notes
Changes the currently defined element types to their corresponding types. Elements without a companion element (listed above) are not switched and should be switched with the ET command to an appropriate element type or to a null element. The KEYOPT values for the switched element types are reset to zero or to their default values. You must check these values to see if they are still meaningful. Additionally, if Cnv = ETI, ITE, or TTE, all real constants are set to zero.
If Cnv = ITE, you will need to choose a material model that corresponds to your previously-defined material properties. If working interactively, you will be prompted to do so.
Element types LINK8 and LINK10 lack a third node; however, their corresponding companion explicit element types, LINK160 and LINK167, require a third (orientation) node. If you are using element types LINK8 or LINK10, you must first convert the element type using this command and then manually define the third node of LINK160 or LINK167 elements using EMODIF.
Also, if you are converting BEAM4 to BEAM161, you may need to manually define the third node of BEAM161 elements as well. However, BEAM4 allows you to define a third, optional node. If you have defined this third node on BEAM4, then the conversion to BEAM161 will be completed automatically when you issue this command. If you did not define the third node on BEAM4, then you must manually define it on BEAM161 using EMODIF.
Element Pairs
ETI -- Explicit to Implicit
160 > 8
161 > 4
163 > 181
164 > 185
165 > 14
166 > 21
167 > 10
ITE -- Implicit to Explicit
4 > 161
8 > 160
10 > 167
14 > 165
21 > 166
181 > 163
185 > 164
TTE --Thermal to Explicit
55 > 162
57 > 163
70 > 164
TTS -- Thermal to Structural
32 > 1
33 > 180
35 > 2
55 > 182
57 > 41
67 > 42
68 > 8
69 > 45
70 > 185
71 > 21
75 > 25
77 > 183
78 > 83
87 > 187
90 > 186
131 > 181
132 > 91/93
151 > 153
152 > 154
157 > 63
STT -- Structural to Thermal
1 > 32
2 > 35
8 > 33
21 > 71
25 > 75
41 > 57
42 > 55
45 > 70
56 > 55
58 > 70
62 > 70
63 > 131
64 > 70
65 > 70
73 > 70
74 > 77
82 > 77
83 > 78
84 > 55/77
86 > 70
88 > 77
89 > 90
91 > 132
92 > 87
93 > 132
95 > 90
106 > 55
107 > 70
108 > 77
153 >151
154 > 152
158 > 87
180 > 33
181 > 131
182 > 55
183 > 77
185 > 70
186 > 90
187 > 87
MTT -- Magnetic to Thermal
53 > 77
62 > 70
96 > 70
97 > 70
117 > 90
119 > 87
120 > 90
FTS -- Fluid to Structural
141 > 42
142 > 45
ETS -- Electrical to Structural
67 > 42
68 > 8
69 > 45
121 > 42/82
122 > 45/95
123 > 92
127 > 92
128 > 45/95
157 > 63
Menu Paths
Main Menu>Preprocessor>Element Type>Switch Elem Type
Contains proprietary and confidential information of ANSYS, Inc. and its subsidiaries and affiliates.
Prev
ETABLE Up / Home Next
ETCONTROL
 楼主| 发表于 2009-5-17 05:57 | 显示全部楼层
回复 板凳 kglxhxg 的帖子
谢谢,明白了!
发表于 2010-4-29 14:42 | 显示全部楼层
我也是碰到类似问题
热分析用的shell132
ETCHG,TTS 命令后
转成了shell182
我用的ansys 11.0帮助里面写的是shell132->shell93啊?
求助
GMT+8, 2025-7-16 05:23 , Processed in 0.080372 second(s), 19 queries , Gzip On.
