查看: 3133|回复: 2
ABAQUS运行错误
发表于 2009-1-7 22:45 | 显示全部楼层 |阅读模式
The executable C:\ABAQUS\6.7-1\exec\standard.exe aborted with system error code 29539. Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same command to run Abaqus that you used when the problem occurred.  Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
怎么时不时地就出现这个错误呢,在网上搜索了下,没得到理想答案
发表于 2009-1-8 20:51 | 显示全部楼层
abaqus job=jobname 试过了没有?
发表于 2009-1-21 15:21 | 显示全部楼层
这是个abaqus很难判断的错误,一般可能是计算资源不足,内存问题,cpu运行不稳定,或者你的模型中有很难察觉的问题。
GMT+8, 2025-1-13 03:08 , Processed in 0.085781 second(s), 18 queries , Gzip On.
