查看: 1125|回复: 0
[分形与混沌] 急救阿,看看问题出在那,作业啊回不了家了
发表于 2009-1-7 11:36 | 显示全部楼层 |阅读模式
数据:data :
527
1160
706
1760
2340
1110
732
537
522
880
654
1040
370
2220
980
285
184
1060
402
350
641
364
152
464
532
600
446
765
506
840
635
590
1050
838
1280
480
3200
2200
781
1640
578
643
652
220
1270
561
1620
770
717
972
104
694
742
344
948
109
程序:
clc
clear all
close all
data = load('d:\c.txt');
时间序列(列向量)
%计算参数
N=length(data);
时间系列长度
tau =10;
时间延迟
min_m= 4;
最小嵌入维
max_m=10;
最大嵌入维
ss = 11;
计算r的步长
for m=min_m:max_m
    Y=reconstitution(data,N,m,tau);%reconstitute state space
    M=N-(m-1)*tau;%the number of points in state space
    for i=1:M-1
        for j=i+1:M
            d(i,j)=max(abs(Y(:,i)-Y(:,j)));%calculate the distance of each two
        end                                %points in state space
计算状态空间中每两点之间的距离
    max_d=max(max(d));%the max distance of all points
得到所有点之间的最大距离
    d(1,1)=max_d;
    min_d=min(min(d));%the min distance of all points
得到所有点间的最短距离
    delt=(max_d-min_d)/ss;%the stepsize of r
得到r的步长
    for k=1:ss
        r=min_d+k*delt;
        C(k)=correlation_integral(Y,M,r);%calculate the correlation integral
        ln_C(m,k)=log(C(k));%lnC(r)
        ln_r(m,k)=log(r);%lnr
        fprintf('%d/%d/%d/%d\n',k,ss,m,max_m);
    plot(ln_r(m,:),ln_C(m,:));
    hold on;
fid=fopen('lnr.txt','w');
fprintf(fid,'%6.2f %6.2f\n',ln_r);
fclose(fid);
fid=fopen('lnC.txt','w');
fprintf(fid,'%6.2f %6.2f\n',ln_C);
fclose(fid)
出错:??? One or more output arguments not assigned during call to 'D:\matlab\work\reconstitution.m (reconstitution)'.
Error in ==> G_P at 12
怎么解决阿
GMT+8, 2024-9-30 05:35 , Processed in 0.061991 second(s), 18 queries , Gzip On.
