查看: 2559|回复: 1
怎么在linux下提交fortran子程序?
发表于 2008-12-28 08:28 | 显示全部楼层 |阅读模式
我在linux下提交子程序据说是把后缀for改成f。可是不能运算,而我的模型和子程序在windows下是能运算的。请高手指点!!
Abaqus JOB /home/mpi/localwork/2ds
Abaqus Version 6.7-2
Begin Compiling Abaqus/Standard User Subroutines
Thu 04 Dec 2008 10:45:14 AM CST
End Compiling Abaqus/Standard User Subroutines
Thu 04 Dec 2008 10:45:15 AM CST
Begin Linking Abaqus/Standard User Subroutines
End Linking Abaqus/Standard User Subroutines
Begin Analysis Input File Processor
Run pre.exe
Abaqus License Manager checked out the following licenses:
Abaqus/Standard checked out 12 tokens.
<3 out of 21 licenses remain available>.
Thu 04 Dec 2008 10:45:19 AM CST
End Analysis Input File Processor
Begin Abaqus/Standard Analysis
Run standard.exe
Thu 04 Dec 2008 10:45:22 AM CST
Abaqus Error: The executable /SOFT/ABAQUS/6.7-2/exec/standard.exe
aborted with system error "Illegal floating point operation" (signal 8).
Please check the .dat, .msg, and .sta files for error messages if the files
exist.  If there are no error messages and you cannot resolve the problem,
please run the command "abaqus job=support information=support" to report and
save your system information.  Use the same command to run Abaqus that you
used when the problem occurred.  Please contact your local Abaqus support
office and send them the input file, the file support.log which you just
created, the executable name, and the error code.
Abaqus/Analysis exited with errors
发表于 2008-12-30 11:08 | 显示全部楼层
fortan对应的CPP版本对吗?
SUSE10.3以上?
GMT+8, 2025-1-26 21:15 , Processed in 0.083798 second(s), 17 queries , Gzip On.
