查看: 3568|回复: 7
[其他相关] 关于PolyMAX的一点介绍,转载
发表于 2006-2-20 20:33 | 显示全部楼层 |阅读模式
  The LMS PolyMAX method is a further evolution of
  the least-squares complex frequency-domain (LSCF)
  estimation method. That method was fi rst introduced to
  fi nd initial values for the iterative maximum likelihood
  method [7]. The method estimates a so-called commondenominator
  transfer function model [8]. Quickly it
  was found that these “initial values” yielded already
  very accurate modal parameters with a very small
  computational effort [7, 9, 10]. The most important
  advantage of the LSCF estimator over the available and
  widely applied parameter estimation techniques [2] is the
  fact that very clear stabilization diagrams are obtained.
  A thorough analysis of different variants of the commondenominator
  LSCF method can be found in [10]. A
  complete background on frequency-domain system
  identifi cation can be found in [11].
  It was found that the identifi ed common-denominator
  model closely fi tted the measured frequency response
  function (FRF) data. However, when converting this
  model to a modal model by reducing the residues to a
  rank-one matrix using the singular value decomposition
  (SVD), the quality of the fi t decreased [9].
  Another feature of the common-denominator
  implementation is that the stabilization diagram can only
  be constructed using pole information (eigenfrequencies
  and damping ratios). Neither participation factors nor
  mode shapes are available at fi rst instance [12]. The
  theoretically associated drawback is that closely spaced
  poles will erroneously show up as a single pole.
  These two reasons provided the motivation for a
  polyreference version of the LSCF method, using a socalled
  right matrix-fraction model. In this approach, also
  the participation factors are available when constructing
  the stabilization diagram. The main benefi ts of the
  polyreference method are the facts that the SVD step
  to decompose the residues can be avoided and that
  closely spaced poles can be separated. The method was
  introduced in [12, 13]. Here we briefl y review the theory.
  Figure 7: Comparison of the measured FRFs (green/grey)
  with FRFs synthesized from the identifi ed modal model
  (black/red). (Top) Sensor at the wing tip; (Bottom) Sensor at
  the back of the plane.
  LMS PolyMAX: Theoretical
  Foundation
  Data model
  Just like the FDPI (Frequency-domain direct parameter
  identifi cation) method1 [4,5], the LMS PolyMAX method
  uses measured FRFs as primary data. Time-domain
  methods, such as the polyreference LSCE method2 [6],
  typically require impulse responses (obtained as the
  inverse Fourier transforms of the FRFs) as primary
  data. In the LMS PolyMAX method, following so-called
  right matrix-fraction model is assumed to represent the
  measured FRFs:
  p p
  [H(jw)]=sum (z ^r[beta_r])*(sum (z ^r[alpha_r])^-1 (1)
  r=0 r=0
  where is the matrix containing the FRFs
  between all m inputs and all l outputs; are the
  numerator matrix polynomial coeffi cients; are
  the denominator matrix polynomial coeffi cients and is
  the model order. Please note that a so-called -domain
  model (i.e. a frequency-domain model that is derived from
  a discrete-time model) is used in (1), with:
  z=exp(-j.w.deltt) (2)
  where is the sampling time.
  Equation (1) can be written down for all values of the
  frequency axis of the FRF data. Basically, the unknown
  model coeffi cients are then found as the Least-
  Squares solution of these equations (after linearization).
  More details about this procedure can be found in[12,13].
  Poles and modal participation factors
  Once the denominator coeffi cients
  are determined,
  the poles and modal participation factors are retrieved
  as the eigenvalues and eigenvectors of their companion
  matrix:
  (3)
  The modal participation factors are the last m rows
  of ; the matrix contains the
  (discrete-time) poles on its diagonal. They are
  related to the eigenfrequencies [rad/s] and damping
  ratios [-] as follows ( •* denotes complex conjugate):
  (4)
  This procedure is similar to what happens in the
  time-domain LSCE method and allows constructing a
  stabilization diagram for increasing model orders
  and
  using stability criteria for eigenfrequencies, damping
  ratios and modal participation factors.
  Mode shapes
  Although theoretically, the mode shapes could be derived
  from the model coeffi cients , we proceed in a
  different way.
  The mode shapes can be found by considering the socalled
  pole-residue model:
  (5)
  where n is the number of modes; denotes complex
  conjugate transpose of a matrix; are the mode
  shapes; are the modal participation factors
  and are the poles (4). are respectively the
  lower and upper residuals modeling the infl uence of the
  out-of-band modes in the considered frequency band.
  The interpretation of the stabilization diagram yields a
  set of poles and corresponding participation factors
  Since the mode shapes and the lower and upper
  residuals are the only unknowns, they are readily obtained
  by solving (5) in a linear least-squares sense. This second
  step is commonly called least-squares frequency-domain
  (LSFD) method [2,3]. The same mode-shape estimation
  method is normally also used in conjunction with the
  time-domain LSCE method.
  References
  [1] VAN DER AUWERAER H., C. LIEFOOGHE, K.
  WYCKAERT AND J. DEBILLE. Comparative study of excitation
  and parameter estimation techniques on a fully equipped car.
  In Proceedings of IMAC 11, the International Modal Analysis
  Conference, 627–633, Kissimmee (FL), USA, 1–4 February 1993
  [2] HEYLEN W., S. LAMMENS AND P. SAS. Modal Analysis
  Theory and Testing. Department of Mechanical Engineering,
  Katholieke Universiteit Leuven, Leuven, Belgium, 1995.
  [3] LMS INTERNATIONAL. The LMS Theory and Background
  Book, Leuven, Belgium, 2000.
  [4] LEMBREGTS F., J. LEURIDAN, L. ZHANG AND H.
  KANDA. Multiple input modal analysis of frequency response
  functions based direct parameter identifi cation. In Proceedings of
  IMAC 4, the International Modal Analysis Conference, 589–598,
  Los Angeles (CA), USA, 1986.
  [5] LEMBREGTS F., R. SNOEYS AND J. LEURIDAN.
  Application and evaluation of multiple input modal parameter
  estimation. International Journal of Analytical and Experimental
  Modal Analysis, 2(1), 19–31, 1987.
  [6] BROWN D.L., R.J. ALLEMANG, R. ZIMMERMAN AND
  M. MERGEAY. Parameter estimation techniques for modal
  analysis. Society of Automotive Engineers, Paper No. 790221,
  1979.
  [7] GUILLAUME P., P. VERBOVEN AND S. VANLANDUIT.
  Frequency-domain maximum likelihood identifi cation of modal
  parameters with confi dence intervals. In Proceedings of ISMA
  23, the International Conference on Noise and Vibration
  Engineering, Leuven, Belgium, 16–18 September 1998.
  [8] GUILLAUME P., R. PINTELON AND J. SCHOUKENS.
  Parametric identifi cation of multivariable systems in the
  frequency domain - a survey. In Proceedings of ISMA 21, the
  International Conference on Noise and Vibration Engineering,
  1069–1082, Leuven, Belgium, 18–20 September 1996.
  [9] VAN DER AUWERAER H., P. GUILLAUME, P.
  VERBOVEN AND S. VANLANDUIT. Application of a faststabilizing
  frequency domain parameter estimation method.
  ASME Journal of Dynamic Systems, Measurement, and Control,
  123(4), 651–658, 2001.
  [10] VERBOVEN, P. Frequency domain system identifi cation for
  modal analysis. PhD Thesis, Vrije Universiteit Brussel, Belgium,
  2002.
  [11] PINTELON R. AND J. SCHOUKENS. System
  Identifi cation: a Frequency Domain Approach. IEEE Press, New
  York, 2001.
  [12] GUILLAUME P., P. VERBOVEN, S. VANLANDUIT, H.
  VAN DER AUWERAER AND B. PEETERS. A poly-reference
  implementation of the least-squares complex frequency-domain
  estimator. In Proceedings of IMAC 21, the International Modal
  Analysis Conference, Kissimmee (FL), USA, February 2003.
  [13] PEETERS B., P. GUILLAUME, H. VAN DER AUWERAER,
  B. CAUBERGHE, P. VERBOVEN AND J. LEURIDAN.
  Automotive and aerospace applications of the LMS PolyMAX
  modal parameter estimation method. In Proceedings of IMAC
  22, Dearborn (MI), USA, January 2004.
  呵呵:)谁想要原文,发email给我吧。
  daviddongsw007@163.com
 楼主| 发表于 2009-8-21 09:54 | 显示全部楼层
原文附上
由于本人不能及时登陆邮箱给与回复。
请从附件中下载文章。
请把后缀.doc去掉后解压即可。共四个文件。
[ 本帖最后由 daviddong 于 2009-8-21 09:56 编辑 ]
PolyMAX.part1.rar.doc
180 KB, 下载次数: 42
PolyMAX.part2.rar.doc
180 KB, 下载次数: 72
PolyMAX.part3.rar.doc
180 KB, 下载次数: 67
PolyMAX.part4.rar.doc
60.72 KB, 下载次数: 47
发表于 2010-11-9 08:52 | 显示全部楼层
⊙﹏⊙b汗,,怎么下不下来啊……
发表于 2010-12-15 09:47 | 显示全部楼层
何必搞得这么玄乎,随处可见的一篇文章,见LMS公司官网:
http://www.lmsintl.com/download.asp?id=8397BE61-F019-4DE2-B365-BB6AC320A776
题目如下:PolyMAX:A Revolution in Modal Parameter Estimation
发表于 2013-10-11 13:19 | 显示全部楼层
多谢楼上的指引!
sem.org-IMAC-XXII-Conf-s01p04-A-Poly-reference-Implementation-Maximum-Likelihood.pdf
529.5 KB, 下载次数: 20
sem.org-IMAC-XXI-Conf-s39p02-A-Poly-Reference-Implementation-Least-Squares-Compl.pdf
408.95 KB, 下载次数: 26
发表于 2014-3-9 17:22 | 显示全部楼层
好东西!!!!!!!!!!!!!
发表于 2014-3-9 17:23 | 显示全部楼层
谢谢楼主!!!!!!!!!!!!!!
谢谢!!!!!!!!!!!!!!!!!!!!!!!
GMT+8, 2025-1-27 00:58 , Processed in 0.094350 second(s), 22 queries , Gzip On.
