查看: 1253|回复: 5
[综合讨论] 请教matlab问题,输出参数问题
发表于 2008-10-24 10:09 | 显示全部楼层 |阅读模式
我编了一个程序,运行时出现下面的问题:One or more output arguments not assigned during call to 'birth4'.我检查了半天没有找到解决办法,请高手指点!谢谢
function [accprob,laplace,N,sm,svar,s,PP,S,Svar,Y1,f,Y2,g,Y3,h,Y4,l,Y5,o,Y6,p,Y7,q,Y8,r,P]=birth4(sm,svar,s,b,d,y,m,laplace0)
  k=4; %k=3 before this step
    %there are two types
    if sm(3,2)~=0&sm(3,6)~=0
        w=unifrnd(0,1);
        if w>=0&w<=1/3 %determine which is the splitting node based on w
            sm(4,1)=1;sm(4,3)=1;s(4,1)=8;s(4,3)=9;
            if svar(1,8)=='y1'&svar(2,4)=='y2'
                svar(3,2)='y3';
                z1=y(:,1);z2=y(:,2);z3=y(:,3);PP='z1=y1z2=y2z3=y3';
                S=[1,2,4];Svar=[1,2,3];
            elseif svar(1,8)=='y1'&svar(2,4)=='y3'
                svar(3,2)='y2';
                z1=y(:,1);z2=y(:,3);z3=y(:,2);PP='z1=y1z2=y3z3=y2';
                S=[1,2,4];Svar=[1,3,2];
            elseif svar(1,8)=='y2'&svar(2,4)=='y1'
                svar(3,2)='y3';
                z1=y(:,2);z2=y(:,1);z3=y(:,3);PP='z1=y2z2=y1z3=y3';
                S=[1,2,4];Svar=[2,1,3];
            elseif svar(1,8)=='y2'&svar(2,4)=='y3'
                svar(3,2)='y1';
                z1=y(:,2);z2=y(:,3);z3=y(:,1);PP='z1=y2z2=y3z3=y1';
                S=[1,2,4];Svar=[2,3,1];
            elseif svar(1,8)=='y3'&svar(2,4)=='y1'
                svar(3,2)='y2';
                z1=y(:,3);z2=y(:,1);z3=y(:,2);PP='z1=y3z2=y1z3=y2';
                S=[1,2,4];Svar=[3,1,2];
            elseif svar(1,8)=='y3'&svar(2,4)=='y2'
                svar(3,2)='y1';
                z1=y(:,3);z2=y(:,2);z3=y(:,1);PP='z1=y3z2=y2z3=y1';
                S=[1,2,4];Svar=[3,2,1];
           N=termsplit(sm);
           [Y1,f,Y2,g,Y3,h,Y4,l,Y5,o,Y6,p,Y7,q,Y8,r,P,c]=parsubsample(N,z1,z2,z3,m);
           laplace=lap4(Y1,Y2,Y3,Y4,f,g,h,l,y,m,c);
           DT=1;
           accprob=laplace/laplace0*poisspdf(k,6)/poisspdf(k-1,6)*d(k)/b(k-1)*1/DT;
        elseif w>1/3&w<=2/3
            sm(4,5)=1;sm(4,7)=1;s(4,5)=10;s(4,7)=11;
                svar(3,6)='y3';
                S=[1,2,5];Svar=[1,2,3];
                svar(3,6)='y2';
                S=[1,2,5];Svar=[1,3,2];
                svar(3,6)='y3';
                S=[1,2,5];Svar=[2,1,3];
                svar(3,6)='y1';
                S=[1,2,5];Svar=[2,3,1];
                svar(3,6)='y2';
                S=[1,2,5];Svar=[3,1,2];
                svar(3,6)='y1';
                S=[1,2,5];Svar=[3,2,1];
           N=termsplit(sm);
           DT=1;
        elseif w>2/3&w<=1
            sm(3,10)=1;sm(3,14)=1;s(3,10)=6;s(3,14)=7;
                v=unifrnd(0,1);
                if v>=0&v<=0.5
                    svar(2,12)='y2';
                    z1=y(:,1);z2=y(:,2);z3=y(:,3);PP='z1=y1z2=y2z3=y3/z1=y1z2=y2z3=y3';
                    S=[1,2,3];Svar=[1,2,2];
                    N=termsplit(sm);
                else
                    svar(2,12)='y3';
                    z1=y(:,1);z2=y(:,2);z3=y(:,3);PP='z1=y1z2=y2z3=y3/z1=y1z2=y3z3=y2';
                    S=[1,2,3];Svar=[1,2,3];
                    N=termsplit(sm);
                   [Y1,f,Y2,g,Y3,h,Y4,l,Y5,o,Y6,p,Y7,q,Y8,r,P,c]=parsubsample2(N,z1,z2,z3,m);
                 v=unifrnd(0,1);
                if v>=0&v<=0.5
                    svar(2,12)='y3';
                    z1=y(:,1);z2=y(:,3);z3=y(:,2);PP='z1=y1z2=y3z3=y2/z1=y1z2=y3z3=y2';
                    S=[1,2,3];Svar=[1,3,3];
                    N=termsplit(sm);
                else
                    svar(2,12)='y2';
                    z1=y(:,1);z2=y(:,3);z3=y(:,2);PP='z1=y1z2=y3z3=y2/z1=y1z2=y2z3=y3';
                    S=[1,2,3];Svar=[1,3,2];
                    N=termsplit(sm);
               v=unifrnd(0,1);
                if v>=0&v<=0.5
                    svar(2,12)='y1';
                    z1=y(:,2);z2=y(:,1);z3=y(:,3);PP='z1=y2z2=y1z3=y3/z1=y2z2=y1z3=y3';
                    S=[1,2,3];Svar=[2,1,1];
                    N=termsplit(sm);
                else
                    svar(2,12)='y3';
                    z1=y(:,2);z2=y(:,1);z3=y(:,3);PP='z1=y2z2=y1z3=y3/z1=y2z2=y3z3=y1';
                    S=[1,2,3];Svar=[2,1,3];
                    N=termsplit(sm);
                v=unifrnd(0,1);
                if v>=0&v<=0.5
                    svar(2,12)='y3';
                    z1=y(:,2);z2=y(:,3);z3=y(:,1);PP='z1=y2z2=y3z3=y1/z1=y2z2=y3z3=y1';
                    S=[1,2,3];Svar=[2,3,3];
                    N=termsplit(sm);
                else
                    svar(2,12)='y1';
                    z1=y(:,2);z2=y(:,3);z3=y(:,1);PP='z1=y2z2=y3z3=y1/z1=y2z2=y1z3=y3';
                    S=[1,2,3];Svar=[2,3,1];
                    N=termsplit(sm);
                v=unifrnd(0,1);
                if v>=0&v<=0.5
                    svar(2,12)='y1';
                    z1=y(:,3);z2=y(:,1);z3=y(:,2);PP='z1=y3z2=y1z3=y2/z1=y3z2=y1z3=y2';
                    S=[1,2,3];Svar=[3,1,1];
                    N=termsplit(sm);
                else
                    svar(2,12)='y2';
                    z1=y(:,3);z2=y(:,1);z3=y(:,2);PP='z1=y3z2=y1z3=y2/z1=y3z2=y2z3=y1';
                    S=[1,2,3];Svar=[3,1,2];
                    N=termsplit(sm);
                v=unifrnd(0,1);
                if v>=0&v<=0.5
                    svar(2,12)='y2';
                    z1=y(:,3);z2=y(:,2);z3=y(:,1);PP='z1=y3z2=y2z3=y1/z1=y3z2=y2z3=y1';
                    S=[1,2,3];Svar=[3,2,2];
                    N=termsplit(sm);
                else
                    svar(2,12)='y1';
                    z1=y(:,3);z2=y(:,2);z3=y(:,1);PP='z1=y3z2=y2z3=y1/z1=y3z2=y1z3=y2';
                    S=[1,2,3];Svar=[3,2,1];
                    N=termsplit(sm);
            DT=2;
    elseif sm(3,10)~=0&sm(3,14)~=0
         w=unifrnd(0,1);
            sm(4,13)=1;sm(4,15)=1;s(4,13)=14;s(4,15)=15;
            if svar(1,8)=='y1'&svar(2,12)=='y2'
                svar(3,14)='y3';
                S=[1,3,7];Svar=[1,2,3];
            elseif svar(1,8)=='y1'&svar(2,12)=='y3'
                svar(3,14)='y2';
                S=[1,3,7];Svar=[1,3,2];
            elseif svar(1,8)=='y2'&svar(2,12)=='y1'
                svar(3,14)='y3';
                S=[1,3,7];Svar=[2,1,3];
            elseif svar(1,8)=='y2'&svar(2,12)=='y3'
                svar(3,14)='y1';
                S=[1,3,7];Svar=[2,3,1];
            elseif svar(1,8)=='y3'&svar(2,12)=='y1'
                svar(3,14)='y2';
                S=[1,3,7];Svar=[3,1,2];
            elseif svar(1,8)=='y3'&svar(2,12)=='y2'
                svar(3,14)='y1';
                S=[1,3,7];Svar=[3,2,1];
            N=termsplit(sm);
            DT=1;
        elseif w>1/3&w<=2/3
            sm(4,9)=1;sm(4,11)=1;s(4,9)=12;s(4,11)=13;
                svar(3,10)='y3';
                S=[1,3,6];Svar=[1,2,3];
                svar(3,10)='y2';
                S=[1,3,6];Svar=[1,3,2];
                svar(3,10)='y3';
                S=[1,3,6];Svar=[2,1,3];
                svar(3,10)='y1';
                S=[1,3,6];Svar=[2,3,1];
                svar(3,10)='y2';
                S=[1,3,6];Svar=[3,1,2];
                svar(3,10)='y1';
                S=[1,3,6];Svar=[3,2,1];
           N=termsplit(sm);
            DT=1;
        elseif w>2/3&w<=1
            sm(3,2)=1;sm(3,6)=1;s(3,2)=4;s(3,6)=5;
                v=unifrnd(0,1);
                if v>=0&v<=0.5
                    svar(2,4)='y2';
                    N=termsplit(sm);
                else
                    svar(2,4)='y3';
                    z1=y(:,1);z2=y(:,2);z3=y(:,3);PP='z1=y1z2=y3z3=y2/z1=y1z2=y2z3=y3';
                    N=termsplit(sm);
                   [Y1,f,Y2,g,Y3,h,Y4,l,Y5,o,Y6,p,Y7,q,Y8,r,P,c]=parsubsample1(N,z1,z2,z3,m);
                 v=unifrnd(0,1);
                if v>=0&v<=0.5
                    svar(2,4)='y3';
                    N=termsplit(sm);
                else
                    svar(2,4)='y2';
                    z1=y(:,1);z2=y(:,3);z3=y(:,2);PP='z1=y1z2=y2z3=y3/z1=y1z2=y3z3=y2';
                    N=termsplit(sm);
               v=unifrnd(0,1);
                if v>=0&v<=0.5
                    svar(2,4)='y1';
                    N=termsplit(sm);
                else
                    svar(2,4)='y3';
                    z1=y(:,2);z2=y(:,1);z3=y(:,3);PP='z1=y2z2=y3z3=y1/z1=y2z2=y1z3=y3';
                    N=termsplit(sm);
                v=unifrnd(0,1);
                if v>=0&v<=0.5
                    svar(2,14)='y3';
                    N=termsplit(sm);
                else
                    svar(2,4)='y1';
                    z1=y(:,2);z2=y(:,3);z3=y(:,1);PP='z1=y2z2=y1z3=y3/z1=y2z2=y3z3=y1';
                    N=termsplit(sm);
                v=unifrnd(0,1);
                if v>=0&v<=0.5
                    svar(2,4)='y1';
                    N=termsplit(sm);
                else
                    svar(2,4)='y2';
                    z1=y(:,3);z2=y(:,1);z3=y(:,2);PP='z1=y3z2=y2z3=y1/z1=y3z2=y1z3=y2';
                    N=termsplit(sm);
                v=unifrnd(0,1);
                if v>=0&v<=0.5
                    svar(2,4)='y2';
                    N=termsplit(sm);
                else
                    svar(2,4)='y1';
                    z1=y(:,3);z2=y(:,2);z3=y(:,1);PP='z1=y3z2=y1z3=y2/z1=y3z2=y2z3=y1';
                    N=termsplit(sm);
             DT=2;
本文来自: 人大经济论坛(http://www.pinggu.org) 详细出处参考:http://www.pinggu.org/bbs/dispbbs.asp?boardid=71&id=375747
[ 本帖最后由 sigma665 于 2008-10-24 17:56 编辑 ]
 楼主| 发表于 2008-10-24 10:18 | 显示全部楼层
还有一个matlab问题要请教
还有一个程序,调用的时候也出现出现下面的错误 One or more output arguments not assigned during call to 'parsubsample'?请求高手指点!谢谢
function [Y1,f,Y2,g,Y3,h,Y4,l,Y5,o,Y6,p,Y7,q,Y8,r,P,c]=parsubsample(N,z1,z2,z3,m)
     m=length(z1);
     c(1)=0;
      if N(1,8)=='terminal'
       P=sym('[ ]');
       f=0;g=0;h=0;l=0;o=0;p=0;q=0;r=0;
       for t=2:m
           f=f+1;
           Y1(f,:)=[z1(t),z2(t),z3(t)];
           c(t)=1;
       Y2=zeros(0,3);Y3=zeros(0,3);Y4=zeros(0,3);Y5=zeros(0,3);
       Y6=zeros(0,3);Y7=zeros(0,3);Y8=zeros(0,3);
发表于 2008-10-24 13:02 | 显示全部楼层
调用函数parsubsample时,输出函数变量没有定义或者输出函数超出了定义时输出函数数。
发表于 2008-10-24 13:05 | 显示全部楼层
回复 楼主 xiuxiamath 的帖子
"output arguments not assigned"不是告诉你的?
输出引数有些没回传, 可能没定义
估计if或for根本没执行
发表于 2008-10-24 13:09 | 显示全部楼层
同另一问题
输出引数有些没回传, 可能没定义
估计if或for根本没执行
 楼主| 发表于 2008-10-24 22:00 | 显示全部楼层
哦,谢谢!我又实验了一次,把parsubsample中的相关内容直接拷到调用该函数的函数文件中,稍微做了一点修改,程序如下:
   直接调用下列函数death1时for循环运行不出来,也就是Y1生成不了,但是把下列函数的内容粘贴到命令窗口中就可以运行,请问这是什么原因?怎么解决呢?
function [accprob,laplace,N,sm,svar,s,PP,S,Svar,Y1,f,Y2,g,Y3,h,Y4,l,Y5,o,Y6,p,Y7,q,Y8,r,P]=death1(sm,svar,s,y,b,d,m,laplace0)
   k=1; %k=2 before this death step
    sm(2,4)=0;sm(2,12)=0;s(2,4)=0;s(2,12)=0;svar(1,8)=sym('[]');
    S=zeros(0,0);Svar=zeros(0,0);
    N=termsplit(sm);
    %the parsubsample function
     m=length(z1);
    %m is the number of elements in z1, z2 and z3
   c(1)=0;
    %to find the corresponding partion of the tree and the corresponding
   %subsamples when svar(1,8)=z1,svar(2,4)=svar(2,,12)=z2,svar(3,2)=svar(3,6)=svar(3,10)=svar(3,14)=z3
    %if the root node is the terminal node
       P=sym('[]');
       for t=2:m
           f=f+1;
           c(t)=1;
       Y2=zeros(0,3);Y3=zeros(0,3);Y4=zeros(0,3);Y5=zeros(0,3);Y6=zeros(0,3);Y7=zeros(0,3);Y8=zeros(0,3);
   %end of parsubsample function
   laplace=lap1(Y1,f,y,m,c);
    DT=1;
   accprob=laplace/laplace0*poisspdf(k,6)/poisspdf(k+1,6)*b(k)/d(k+1)*DT;
GMT+8, 2024-10-1 23:29 , Processed in 0.063606 second(s), 19 queries , Gzip On.
