查看: 1020|回复: 3
[前后处理] 帮忙看看我的图形!
发表于 2008-8-27 20:12 | 显示全部楼层 |阅读模式
如何才能把两个圆柱立起来啊,我怎么整也整不过来,请帮帮忙吧,谢谢啦!!
发表于 2008-8-28 08:42 | 显示全部楼层
回复 楼主 guo721 的帖子
在柱坐标系做Y轴的move
发表于 2008-8-28 10:53 | 显示全部楼层
/vup
发表于 2008-8-29 14:33 | 显示全部楼层
回复 板凳 sogooda 的帖子
这个命令好。
/VUP, WN, Label
Specifies the global Cartesian coordinate system reference orientation.
GRAPHICS: Views
WN
Window number (or ALL) to which command applies (defaults to 1).
Label
Orientation:
Y    —  Y vertical upward, X horizontal to the right, Z out from the screen (default).
-Y    —  Y vertical downward, X horizontal to the left, Z out from the screen.
X    —  X vertical upward, Y horizontal to the left, Z out from the screen.
-X    —  X vertical downward, Y horizontal to the right, Z out from the screen.
Z    —  Z vertical upward, Y horizontal to the right, X out from the screen. With this choice, you should use a view other than the /VIEW default of (0,0,1).
-Z    —  Z vertical downward, Y horizontal to the left, X out from the screen. With this choice, you should use a view other than the /VIEW default of (0,0,1).
GMT+8, 2025-1-13 02:31 , Processed in 0.064979 second(s), 21 queries , Gzip On.
