查看: 5488|回复: 12
[其他相关] DyRoBeS home page
发表于 2005-7-5 13:10 | 显示全部楼层 |阅读模式
<!--msnavigation-->
<TABLE dir=ltr cellSpacing=0 cellPadding=0 width="100%" border=0>
<TR>
<TD vAlign=top width="1%"></TD>
<TD vAlign=top width=24></TD><!--msnavigation-->
<TD vAlign=top>
<TABLE height="100%" width="100%" border=1>
<TR>
<TD vAlign=top align=middle width="20%" bgColor=#ffffff height="100%">
<P ><IMG src="http://www.dyrobes.com/ETILogo.jpg" border=0></P>
<P > </P>
<P ><FONT color=#0000ff><B><a href="http://www.dyrobes.com/index.htm" target="_blank" >Home</A></B></FONT></P>
<P > </P>
<P ><B><a href="http://www.dyrobes.com/Rotordynamics.htm" target="_blank" ><FONT color=#0000ff>Rotordynamics</FONT></A></B> </P>
<P ><B><FONT color=#000080><a href="http://www.dyrobes.com/RotordynamicsModel.htm" target="_blank" >Model</A></FONT></B> </P>
<P ><B><FONT color=#000080><a href="http://www.dyrobes.com/lateral_vibration.htm" target="_blank" >Lateral</A></FONT></B> </P>
<P ><B><FONT color=#000080><a href="http://www.dyrobes.com/torsional_vibration.htm" target="_blank" >Torsional</A></FONT></B> </P>
<P ><B><FONT color=#000080><a href="http://www.dyrobes.com/axial_vibration.htm" target="_blank" >Axial</A></FONT></B> </P>
<P ><B><FONT color=#000080><a href="http://www.dyrobes.com/tools.htm" target="_blank" >Tools</A></FONT></B> </P>
<P><a href="http://www.dyrobes.com/BePerf.htm" target="_blank" ><B><FONT color=#0000ff>Bearings</FONT></B></A> </P>
<P><B><a href="http://www.dyrobes.com/FEA.htm" target="_blank" ><FONT color=#0000ff>Finite Element Analysis </FONT></A></B></P>
<P><a href="http://www.dyrobes.com/DataAcquisitionServices.htm" target="_blank" ><B><FONT color=#0000ff>Data Acquisition </FONT></B></A></P>
<P><a href="http://www.dyrobes.com/GearLoad.htm" target="_blank" ><B><FONT color=#0000ff>Gear Load</FONT></B></A></P>
<P><B><FONT color=#0000ff><a href="http://www.dyrobes.com/what_is_new.htm" target="_blank" >What is New</A></FONT></B></P>
<P><a href="http://www.dyrobes.com/ContactUs.htm" target="_blank" ><B><FONT color=#0000ff>Contact us</FONT></B></A></P>
</TD>
<TD width="80%" height="100%">
<P  align=center><B><FONT color=#000080 size=4>Welcome to </FONT><FONT color=#000080 size=5>DyRoBeS</FONT><FONT color=#000080 size=4> home page</FONT></B></P>
<HR>
<P ><FONT color=#0000ff size=3><B>DyRoBeS</B></FONT><FONT color=#0000ff><B>&copy;</B></FONT><FONT color=#0000ff> (<U>Dy</U>namics of <U>Ro</U>tor <U>Be</U>aring <U>S</U>ystems) </FONT>is a powerful and complete rotor dynamics and bearing analysis program based on Finite Element Analysis.  </P>
<P><STRONG>A comprehensive rotordynamics book by W. J. Chen &amp; E. J. Gunter</STRONG> </P>
<P ><IMG src="http://www.dyrobes.com/BookCover.bmp" align=left border=0>  <a href="http://www.dyrobes.com/Table%20of%20Contents.pdf" target="_blank" >Click here for Table of Contents</A> </P>
<P>  <a href="http://www.dyrobes.com/About%20the%20Authors.pdf" target="_blank" >Click here for About the Authors</A> </P>
<P>  <a href="http://www.dyrobes.com/Chapter3_Excerpt.pdf" target="_blank" >Click here for excerpt from Chapter 3</A> </P>
<P>  469 pages; <B>US$125.00+SH</B> </P>
<P ><B>   Click PayPal Below to buy </B> </P>
<FORM action=https://www.paypal.com/cgi-bin/webscr method=post>
<P ><INPUT>   <INPUT> <INPUT> </FORM>
<P >   <IMG src="http://www.dyrobes.com/CreditCard_solution_PP.gif" border=0>  </P>
<P >   or buy from: </P>
<P >  </P>
<P >   <a href="http://www.rodyn.com/" target="_blank" >www.RODYN.COM</A> </P>
<P>   <a href="http://www.amazon.com/" target="_blank" >www.amazon.com</A>   </P>
<P ><B>About</B> <B><I>DyRoBeS&copy;</I></B><P> </P></P>
<P > <B><I>DyRoBeS</I></B>&copy; is a pair of powerful, yet easy to learn and use, engineering design/analysis software tools authored by Wen Jeng Chen, Ph.D., P.E., for complete rotor dynamics analysis and comprehensive bearing performance calculations.  The Finite Element based codes combine a user interface intuitive enough for the occasional user, with a powerful set of modeling and analysis capabilities for the most demanding requirements.  Extensive built-in modeling, analysis, post-processing and visualization tools allow the user to work within a single integrated environment.  To aid the user, the programs include context sensitive help, a standard <I >Windows</I> help system, and an extensive set of examples.<P> </P></P>
<P ><B><I>DyRoBeS-Rotor</I></B> is the <U>Rotor</U> dynamics component.  Developed with the basic philosophy of providing powerful, but easy to use tools for the working engineer, <B><I>DyRoBeS-Rotor</I></B><B >, </B>is capable of linear and non-linear analyses of free and forced vibrations (lateral, torsional, and axial) as well as static deflections of multi-shaft and multi-branch flexible rotor-bearing-support systems.  More than ten different types of bearings, dampers, and seals are built in.  In additional, a number of analysis and design tools, including aerodynamic cross-coupling calculations, rolling element deflection and stiffness estimation, liquid annular seal analysis, calculation of inertia properties of a solid, equivalent impedance of a bearing-support system, rotor orbit analysis, and balancing calculations are provided.<B ><P> </P></B></P>
<P ><B><I>DyRoBeS-BePerf</I></B> complements <B><I>DyRoBeS-Rotor</I></B> by calculating <U>Be</U>aring steady state and dynamic <U>Perf</U>ormance.  The wide range of bearing configurations which can be analyzed include plain cylindrical, partial arc, elliptical, lobed, multi-pocket, pressure dam, general fixed profile lobed, flexural/tilting pad with or without flexible pivots, floating ring bushings, gas lubricated bearings, and thrust bearings.  The solution includes automatic calculation of effective film temperatures at operating conditions.  In addition to bearing analysis, the program also performs lubricant properties analysis and oil flow calculations.  The bearing dynamic coefficients calculated by using <B><I>DyRoBeS-BePerf</I></B> can be easily integrated into a <B><I>DyRoBeS-Rotor</I></B> model.<P> </P></P>
<P >Under continuous development since 1991, <B><I>DyRoBeS</I></B> has been rigorously validated and extensively tested by many academic researchers and industrial engineers.  It is widely used by government agencies, universities, and various industries around the world.  <P></P></P>
<P  align=center><B><I>DyRoBeS</I> model for a Turbine Generator<P> </P></B></P>
<P  align=center><B><V:SHAPETYPE><V:STROKE joinstyle="miter"></V:STROKE><V:FORMULAS><V:F eqn="if lineDrawn pixelLineWidth 0"></V:F><V:F eqn="sum @0 1 0"></V:F><V:F eqn="sum 0 0 @1"></V:F><V:F eqn="prod @2 1 2"></V:F><V:F eqn="prod @3 21600 pixelWidth"></V:F><V:F eqn="prod @3 21600 pixelHeight"></V:F><V:F eqn="sum @0 0 1"></V:F><V:F eqn="prod @6 1 2"></V:F><V:F eqn="prod @7 21600 pixelWidth"></V:F><V:F eqn="sum @8 21600 0"></V:F><V:F eqn="prod @7 21600 pixelHeight"></V:F><V:F eqn="sum @10 21600 0"></V:F></V:FORMULAS><V:PATH extrusionok="f" gradientshapeok="t" connecttype="rect"></V:PATH><LOCK v:ext="edit" aspectratio="t"></LOCK></V:SHAPETYPE><V:SHAPE><V:IMAGEDATA></V:IMAGEDATA></V:SHAPE><IMG src="http://www.dyrobes.com/index.1.jpg"></B><P> </P></P>
<P>        ISBN 1-4120-5190-8<P> </P></P>
<CENTER>
<HR>
<H5  align=left><IMG src="http://www.dyrobes.com/WJ%20company%20title(small).bmp" border=0></H5>
<H5  align=left>Wen Jeng Chen, Ph.D., P.E.<BR>Copyright &copy; Eigen Technologies, Inc.   All rights reserved.<BR>Revised: <!--webbot bot="TimeStamp" S-Type="EDITED" S-Format="%B %d, %Y" startspan
        -->July 03, 2005<!--webbot bot="TimeStamp" endspan i-checksum="14208"
        --> .</H5></CENTER></TD></TR></TABLE>
<!--msnavigation--></TD></TR><!--msnavigation--></TABLE>
 楼主| 发表于 2005-7-5 13:24 | 显示全部楼层
[分享]计算机仿真技术应用简介
<a href="http://www.dyrobes.com/" target="_blank" >http://www.dyrobes.com/</A>
发表于 2005-7-6 09:13 | 显示全部楼层
倒啊,看来你转贴水平不够,哈哈~~
发表于 2005-7-7 12:26 | 显示全部楼层
<P>功能不错啊</P>
发表于 2005-7-7 14:01 | 显示全部楼层
<DIV class=quote><B>以下是引用<I>二锅头</I>在2005-7-7 12:26:22的发言:</B><BR>
<P>功能不错啊</P></DIV>
<P>但是感觉不实用</P>
 楼主| 发表于 2005-7-7 20:11 | 显示全部楼层
<DIV class=quote><B>以下是引用<I>aspen</I>在2005-7-6 9:13:18的发言:</B><BR>倒啊,看来你转贴水平不够,哈哈~~</DIV>
<P>看不懂网页的源代码,copy过来是啥样就啥样了,要不就转到文本编辑器里面只要文字,我就只会这么干!</P>[em07]
发表于 2005-7-8 14:45 | 显示全部楼层
<DIV class=quote><B>以下是引用<I>linda</I>在2005-7-7 14:01:55的发言:</B><BR><BR>
<P>但是感觉不实用</P></DIV>
<br>咋不实用?
发表于 2005-8-23 12:38 | 显示全部楼层
不错,多少钱啊<BR>
发表于 2005-9-12 12:25 | 显示全部楼层
回复:(董礼)不错,多少钱啊
<DIV class=quote><B>以下是引用<I>董礼</I>在2005-8-23 12:38:17的发言:</B><BR>不错,多少钱啊<BR></DIV>
<P>代理商说是1万美元,国内还只有8个用户,现在他们急着扩展业务,估计可以讲价</P>
发表于 2005-12-10 16:02 | 显示全部楼层
回复:(心灯)[分享]计算机仿真技术应用简介
<P>    哪位大哥能帮帮忙,给点dyrobes资料,我第一年工作,师傅让我用dyrobes,可是一点资料都没有,我都没有听说过这个软件,根本不会,在网上也没有资料。请大哥帮帮忙吧!!!!<BR><a href="mailtyinyuen@sohu.com" target="_blank" >yinyuen@sohu.com</A><BR>谢谢</P>
发表于 2006-6-23 15:34 | 显示全部楼层
回复:(FSI)以下是引用linda在2005-7-7 14:01:55的发...
<DIV class=quote><B>以下是引用<I>FSI</I>在2005-7-8 14:45:55的发言:</B><BR><BR><BR>咋不实用?</DIV>
<P>这个软件出的图很多都是示意图,根本没有实用价值。感觉它就是做个界面,把现有的转子动力学公式放进去。计算中对模型也简化的厉害,很多实际中的情况都被忽略了,结果可想而知。所以感觉这个东西买1W美刀不值。<BR>另个,它的国内代理的技术支持工程师很烂,问什么问题都不知道,郁闷死了</P>
发表于 2006-8-22 16:59 | 显示全部楼层
新手上路
Sample TextSample Text
DyRoBeS BePerf是否有滚主轴承计算的模块?
发表于 2013-1-7 07:03 | 显示全部楼层
什么啊
GMT+8, 2025-1-13 14:16 , Processed in 0.067774 second(s), 20 queries , Gzip On.
