查看: 1915|回复: 3
[Virtual.Lab] sysnoise求解时候突然退出
发表于 2008-7-30 15:06 | 显示全部楼层 |阅读模式
以下是代码,初次使用sysnoise,版本是5.6,但是打开显示是5.5,按其第一个例子顺便做下来的,一切顺利,但是指定solve的频率后按 ok,之后就自动退出了,非常的迷惑之中,
可以参看journal文件的最后一句return之后就没有了
New Name 'Car_NoTrim' Model 1 File Car_NoTrim.sdb Return
Option  BEM Direct Collocation Element Interior Uncoupled Frequency  Return
Import Mesh Format Free File d:\sysnoisework\monovolume.fre Return
Check Mesh Return
Material Fluid
    Name 'air'
    Sound Real 3.4000e+002  Rho Real 1.2250e+000
    Return
Check Mesh Set Featuredomain Angle 50 Return
Generate
    Element Set 1
    Element Set 2
    Element Set 3
    Element Set 4
    From Displacements File  d:\sysnoisework\firewall_disp.pch Format Nastran
    Frequency 10 To 100 LinStep 2
    Mesh File  d:\sysnoisework\firewall.bdf Format Nastran
    Algorithm  1  Tolerance 0.05 Average 1
    Return
Save Return
Save File  d:\sysnoisework\carnotrim Return
Save Return
Parameter Model 1
    Physical
    Save Potentials Step 1
    Save Results none
    Store Potentials none
    Return
    Store Results none
    Return
    Near 2
    Far 5
    Quadrature 2 2 1
    Return
FMaximum 6 Return
Solve
    Return
发表于 2008-7-30 15:53 | 显示全部楼层
你这种情况是因为所用的5.6的lic文件问题。里面对求解器的破解不全,BEM求解器根本就没有解锁,你当然用不了,所以在solve过程中会出错,自己可以查看下,在程序solve后面可能会这样:
SOLVE PARAMETERS
MODEL:   1 - IBEM3
    PHYSICAL Coordinates
    Saving POTENTIALS every        1 steps
    No saving of RESULTS
    Energy Calculation Enabled
    Surface post-processing on positive side
    Quadrature info
       Proximity limits (multiplied by mean edge) :
         Near area <  2        < medium area <  5        < far area
       Selected integration quadratures:
                 Near region  :    2
                 Medium region:    2
                 Far region   :    1
       Quadrature Nr   Line  Triangle  Quadrangle
                   0   0-pt     0-pt       0-pt
                   1   1-pt     1-pt       1-pt
                   2   2-pts    4-pts      4-pts
                   3   3-pts    7-pts      9-pts
                   4   4-pts   13-pts     16-pts
                   5   5-pts   13-pts     25-pts
                  10  10-pts   13-pts    100-pts
                  16  16-pts   13-pts    100-pts
                  24  24-pts   13-pts    100-pts
LAUNCHING UNCOUPLED ACOUSTIC INDIRECT BEM (Freq) ANALYSIS
A FATAL ERROR OCCURRED.  PROGRAM STOPPED
呵呵,肯定出错。还是用5.5好
 楼主| 发表于 2008-7-31 13:57 | 显示全部楼层
原帖由 minetree 于 2008-7-30 15:53 发表
SOLVE PARAMETERS
MODEL:  ...
谢谢minetree的回复呢,
(1)>>feild point plane 如何在 colormap中只是 这个平面的结果, 而不是整个mesh呢.
Sysnoise和Ansys的思路不一样;你只要定义了场点面,那么它就会计算场点面的Resutls,但这时Model mesh计算出来的量称为potentials,你在显示时,首先在对话框中选择是Model mesh还是场点,然后再选择其他
(2)>>计算的solve的时候,也曾 不指定frequency直接算了,然后终止,
然后再指定频率计算,好像就可以了,不知道为什么,是什么原因
必须要指定频率才能计算的,否则程序会出错
原始短消息: 莫名的好了, 又有了新问题,sysnoise
引用:
总之莫名其妙的好了,不过如果我定义了 feild point plane 如何在 colormap中只是 这个平面的结果, 而不是整个mesh呢.
因为刚才改了论坛帐号的密码 结果不可以回复了 只好直接发消息了
而且想是否有qq群是关于 sysnoise的呢
初学 所以问题可能描述得 不是太好呢
做第一个例子的时候,反复出错,一到计算solve的步骤,便自动退出了,真是要命,
后来找其它的licence好像也,不可以
反正后来把exceed关掉 重启后,好像就好了 真不知道是怎么回事呢,
那个5.6反正是没装成功,
还报告 vendor daemon is old
幸亏 fluent安装的时候 装了exceed了,
而 lmtools (licence management tools 好像也是有了的,因为装了 hypermesh ,所以)
后来在场点选择的时候似乎又出了问题 自动关闭了
这个东东似乎
以上是minetree和我的消息交流
后来选择 场点 果然是好的  谢谢minetree
发表于 2008-7-31 16:10 | 显示全部楼层
呵呵,也谢谢 alljoyland把图片贴出来和大家分享经验:@)
GMT+8, 2024-10-2 03:28 , Processed in 0.066813 second(s), 22 queries , Gzip On.
