查看: 2064|回复: 3
[前后处理] 单元实常数问题
发表于 2008-7-20 21:23 | 显示全部楼层 |阅读模式
    我在对一矩形截面简支梁(截面宽B=0.2m,截面高H=0.3m)进行模态
分析时,选取的单元类型是beam3梁单元,在定义单元实常数时我的做
法:preprocessor/sections/beam/common sections,选择矩形截面,
输入截面参数B=0.2m,H=0.3m,通过preview得到的截面参数是:
Area=0.06,IYY=0.450E-03,IYZ=0,IZZ=0.200E-03;
    之后我又通过Utility Menu/Parameters/Scalar Parameters,在
弹出的Scalar Parameters对话框中输入B=0.2m,H=0.3m,
Xsect=B*H,Inertiaz=(B*H**3)/12,得到的结果是:
Xsect=0.06,Inertiaz=0.45E-03;
    这儿我不明白:1.为什么Xsect不等于IZZ,而是等于IYY? 2.
定义beam3单元的实常数时,需入的截面参数是IZZ,那我究竟应该输入那
个值呢???
    还望各位高人赐教!!!
    不胜感激!!!
[ 本帖最后由 16443 于 2008-7-21 11:40 编辑 ]
发表于 2008-7-21 11:42 | 显示全部楼层
回复 楼主 的帖子
看一下IZZ的定义吧
发表于 2008-7-21 13:40 | 显示全部楼层
呵呵,界面定义的默认坐标系就是x-y坐标系,自然就是关于y的惯性矩了
发表于 2008-7-21 15:05 | 显示全部楼层
Maybe you should make Ixx, Izz clear firstly, for example, you can clarify the section capacity of different axis, area moment of interia  for  X-X  direction is in resistance to wind load , and area moment of interia  for  Y-Y direction  is in resistance to dead load !That's to say, you must know the usage of the physicals! Here the example  : Ixx is used to calculate the deflection under wind load , and Iyy is used to calculate the defletion due dead load !     I have no china softs in my computer, so I have to answer your questions in English, sorry for that!
GMT+8, 2025-1-13 05:54 , Processed in 0.059852 second(s), 18 queries , Gzip On.
