查看: 2066|回复: 6
[Virtual.Lab] SYSNOISE计算时出错
发表于 2008-6-26 09:04 | 显示全部楼层 |阅读模式
我计算的模型比较大,开始计算一段时间后,它总要由于错误自动停止计算,
下面是Echo里面的信息,我读不懂,请教一下大家是什么原因?
Block   166 , Number of collocation points to process:   200
Block   167 , Number of collocation points to process:   200
ERROR    38 ON UNIT  27 WHEN WRITING BLOCK       167
Block   168 , Number of collocation points to process:   200
ERROR    38 ON UNIT  27 WHEN WRITING BLOCK       168
Block   169 , Number of collocation points to process:   200
ERROR    38 ON UNIT  27 WHEN WRITING BLOCK       169
Block   170 , Number of collocation points to process:   200
ERROR    38 ON UNIT  27 WHEN WRITING BLOCK       170
Block   171 , Number of collocation points to process:   200
ERROR    38 ON UNIT  27 WHEN WRITING BLOCK       171
Block   172 , Number of collocation points to process:   200
ERROR    38 ON UNIT  27 WHEN WRITING BLOCK       172
Block   173 , Number of collocation points to process:   200
ERROR    38 ON UNIT  27 WHEN WRITING BLOCK       173
Block   174 , Number of collocation points to process:   200
ERROR    38 ON UNIT  27 WHEN WRITING BLOCK       174
Block   175 , Number of collocation points to process:   200
ERROR    38 ON UNIT  27 WHEN WRITING BLOCK       175
Block   176 , Number of collocation points to process:   200
ERROR    38 ON UNIT  27 WHEN WRITING BLOCK       176
Block   177 , Number of collocation points to process:   200
ERROR    38 ON UNIT  27 WHEN WRITING BLOCK       177
CPU Stats --- Delta:  0:47:06 (   2826.31)  Total:  1:00:58 (   3657.68)
SOLVING SYSTEM OF EQUATIONS (OUT OF CORE SOLVER)
Beginning matrix decomposition
      Block #    1
Error in direct file access
ERROR SOLVING SYSTEM OF EQUATIONS
CPU Stats --- Delta:  0:56:44 (   3403.53)  Total:  1:57:41 (   7061.21)
Processing load case    1
Determining Radiated Sound Power From The BE Mesh:
      Input Power:            2.17018897E-05
      Mean Quad Velocity:     5.43817506E-10
      Active Output Power:   -2.42290005E-06
      Reactive Output Power:  1.98327528E-24
      Radiation Efficiency:  -0.11164466
SAVING POTENTIALS    INTO DATABASE
ERROR ON UNIT    81 IN WRITING RECORD        45
  PROCEDURE STOPPED DUE TO ERROR !
请问高手 该如何解决?
发表于 2008-7-4 11:53 | 显示全部楼层
.log的其他信息有吗??贴出来方便大家帮你排查
发表于 2008-7-4 21:20 | 显示全部楼层
模型规模太大导致的,在分块计算的时候无法处理。Beginning matrix decomposition
      Block #  1
建议把BE的网格规模缩小
或者提高内存空间
发表于 2008-7-6 09:38 | 显示全部楼层
请教一下规模多少的限制怎么算,和内存的关系是怎样?
 楼主| 发表于 2008-7-19 14:15 | 显示全部楼层
同意chourhy兄的意见,我将模型改小了,确实再没有上述错误发生。谢谢!
可是内存空间SYSNOISE最大只能占用到500,已经无法再提高了:@L
发表于 2011-2-12 15:23 | 显示全部楼层
我也出现类似的问题
FREQUENCY RESPONSE MODULE
FOR    1 FREQUENCIES FROM     1000.000 TO     1000.000 HZ
ANALYSIS #     1  FREQUENCY =       1000.000 HZ  TYPE = NORMAL
SOLVE PARAMETERS
MODEL:   1 - 211
    PHYSICAL Coordinates
    Saving POTENTIALS every        1 steps
    No saving of RESULTS
    Energy Calculation Enabled
    Surface post-processing on positive side
    Quadrature info
       Proximity limits (multiplied by mean edge) :
         Near area <  2        < medium area <  5        < far area
       Selected integration quadratures:
                 Near region  :    2
                 Medium region:    2
                 Far region   :    1
       Quadrature Nr   Line  Triangle  Quadrangle
                   0   0-pt     0-pt       0-pt
                   1   1-pt     1-pt       1-pt
                   2   2-pts    4-pts      4-pts
                   3   3-pts    7-pts      9-pts
                   4   4-pts   13-pts     16-pts
                   5   5-pts   13-pts     25-pts
                  10  10-pts   13-pts    100-pts
                  16  16-pts   13-pts    100-pts
                  24  24-pts   13-pts    100-pts
LAUNCHING UNCOUPLED ACOUSTIC DIRECT BEM ELEMENT (Freq) ANALYSIS
SAVING MODEL 211
FILE NAME    _211.sdb
NUMBER OF RHS   =    1
NUMBER OF BLOCKS=    1
SIZE OF BLOCKS  =    1
NOT ENOUGH MEMORY AVAILABLE
AVAILABLE MEMORY:   500000000 WORDS
Numbering BEM fluid degrees of freedom
THIS PROBLEM WOULD NEED      0.89249058E+10 WORDS TO RUN IN-CORE
SELECTING THE OUT-OF-CORE SOLVER
Number of equations =       47202
Number of blocks    =         237
Block size          =       40000
Block order         =         200
System order        =       47400
REQUIRED DISK SPACE =  -32770.558 MEGABYTES
Occupied space:  50524945 words  ( 10.10 %)
Estimated CPU time for assembling:         978181.85 sec
Estimated CPU time for solving:          55087692.04 sec
Total estimated CPU time for 1 frequency:56065873.89 sec
This node (wbb) has number 0
ANALYSIS NUMBER      1 /      1                FREQUENCY =   1000.000 Hz
CPU Stats --- Delta:  0:29:28 (   1767.75)  Total:  0:35:41 (   2141.26)
Building the matrix of BEM coefficients
Block     1 , Number of collocation points to process:   200
……………………………………………… 中间省略
Block    237 , Number of collocation points to process:   200
  CPU Stats---Delta:  1:26:38 (4538.50)    Total:1:51:20(6679.76)
solving system of equations (out of core solver)
beginning matrix decompositon
     BLOCK # 1
     BLOCK # 2
到这个位置的时候,就停住没有下文了,SCL history 里面是空的,没有文字
主界面打不开,或者打开了也是一片蓝色,鼠标变成小时钟的样子。但是LOG中没有提示出现error啊,不知道是不是和一楼同样的问题。但是我必须要计算这个频率,网格不能画的大,现在这个网格密度正好可以计算1K。
我的模型是比较大,但是实际情况就是这样的,也没有办法改啊
不知道这种情况到底怎么办呢
发表于 2011-5-20 16:38 | 显示全部楼层
回复 6 # yesangle 的帖子
我刚刚也出现了这个问题,不知道楼上是怎么解决的啊?
GMT+8, 2024-10-1 15:27 , Processed in 0.060102 second(s), 19 queries , Gzip On.
