查看: 1912|回复: 1
[综合讨论] 请教:可以帮忙解决一下这几个运行中遇到的错误吗?十分感谢,急用
发表于 2008-5-28 16:34 | 显示全部楼层 |阅读模式
我是个初学者老师让建一个十七层的大楼模型出现了这几个错误,希望能帮我一下,多谢!
1.*** WARNING ***                         CP =      23.156   TIME= 14:41:30
Unselected line 4.
2.    *** WARNING ***                         CP =      40.000   TIME= 14:41:47
After NUMMRG,ALL, node 13730 (and possibly others) is associated with
more than one solid model entity.  Future commands which depend on the
node to solid model connectivity (meshing, mesh clearing, solid
boundary condition transfer, etc.) may not operate properly.
3.      *** WARNING ***                         CP =      40.609   TIME= 14:41:49
Real constant 1 referenced by at least element types 1 and 2.
4.         *** ERROR ***                           CP =     671.812   TIME= 14:53:00
Large negative pivot value ( -1.636456384E+14 ) in Eqn.system.  May be
because of a bad temperature-dependent material property used in the
model.
5.        *** WARNING ***                         CP =     672.000   TIME= 14:56:36
Small negative equation solver pivot term encountered at ROTY DOF of
node 100565.  Check for an insufficiently constrained model.
/COM,ANSYS RELEASE 11.0    UP20070125       15:02:37    05/28/2008
发表于 2008-5-28 22:28 | 显示全部楼层
回复 楼主 的帖子
已经提示的很清楚了,还要别人怎帮忙啊。
帮助你做模型、计算么 ?
GMT+8, 2025-1-13 07:57 , Processed in 0.073938 second(s), 17 queries , Gzip On.
