查看: 1389|回复: 2
[编程技巧] 如何从 txt 文件中读入和提取感兴趣的数据
发表于 2008-5-12 16:03 | 显示全部楼层 |阅读模式
请问各位大侠,我有一数据如下所示,请问如何用matlab读入并取出其中 95-122E,0-25N的数据 ? 谢谢:loveliness:
Data are stored in ASCII
All values are integers
Temperatures are stored as degrees C * 100
100% sea-ice-covered gridboxes are flagged as -1000
Land squares are set to -32768
The day, month and year are stored at the start of each month. The day simply tells
you on which day the month starts.
Data Array (360x180)
Item (  1,  1) stores the value for the 1-deg-area centred at 179.5W and 89.5N
Item (360,180) stores the value for the 1-deg-area centred at 179.5E and 89.5S
         | DAY | MON | YR  |
         |_____|_____|_____|____________________________
     90N |(1,1)                                         |
         |(1,90)                                        |
     Equ |                                              |
         |(1,91)                                        |
     90S |(1,180)______________________________(360,180)|
          180W                 0                    180E
[ 本帖最后由 eight 于 2008-5-12 19:40 编辑 ]
发表于 2008-5-12 16:18 | 显示全部楼层
原帖由 hzxiaofen 于 2008-5-12 16:03 发表
Temperatures are stored as degrees C ...
请搜索版面的精华帖或浏览置顶帖,里面有您想要的
发表于 2008-5-12 19:39 | 显示全部楼层
不知所云,我都没看见 95-122E 这些数据
GMT+8, 2025-2-20 11:26 , Processed in 0.075901 second(s), 18 queries , Gzip On.
