查看: 908|回复: 2
[CFD及热分析] 请教一下,关于电流加热的加载
发表于 2008-4-10 17:36 | 显示全部楼层 |阅读模式
我在做一个电流加热的温度场计算,除了要计算的模型,还有外电阻,外电阻在整个的计算过程中电阻是不变的,因此我要为加载的电压设定一个函数,请问怎么设置啊?
另一个问题,在模型的边界条件的设定上,由于外界温度是一个曲线,请问怎么设置?
希望各位能人不吝赐教!
 楼主| 发表于 2008-4-11 14:45 | 显示全部楼层
怎么没有人回复啊?各位高手帮帮忙啊!:'(
发表于 2008-4-30 18:26 | 显示全部楼层
You can use the Function Tool to apply complicated boundary conditions on a model. The Function Tool has two parts: the Function Editor creates an arbitrary equation or function (multiple equations), and a Function Loader retrieves the functions and loads them as TABLE arrays. They are then applied to a model using the tabular boundary condition process described in Applying Loads Using TABLE Type Array Parameters.
You must define your function and load it as a TABLE array before you try to add it as a load. You can access the Function Editor either via Utility Menu> Parameters> Functions> Define/Edit, or via Main Menu> Solution> Define Loads> Apply> Functions> Define/Edit. You can access the Function Loader either via Utility Menu> Parameters> Functions> Read from file, or via Main Menu> Solution> Define Loads> Apply> Functions> Read file
GMT+8, 2025-1-27 18:36 , Processed in 0.092387 second(s), 18 queries , Gzip On.
