查看: 2933|回复: 4
[结构分析] 求教使用ANSYS/LS DYNA 做跌落分析时,使用ANSYS自己的计算同使用LS970计算之间的差别
发表于 2008-3-11 13:20 | 显示全部楼层 |阅读模式
在工作中遇到这样的问题
用ANSYS划分网格后,写成K文件,在修改文件的时候老出问题
但是用ANSYS直接求解是没问题的
我想知道 用ANSYS直接求解和使用LS求解之间的差别大不大?
发表于 2008-3-11 21:25 | 显示全部楼层
有很大的区别,一个是ANSYS;一个是LS-DYNA的,显示计算,做的是动态碰撞分析,模拟跌落过程较为准确。两者所用的求解器不一样,计算方法也不一样。
 楼主| 发表于 2008-3-12 08:38 | 显示全部楼层
好象不对的
但是ANSYS求解也是调用的LS DYNA的求解截面. 出现的DOS框是970的求解框. 我做的是这样的
 楼主| 发表于 2008-3-12 08:40 | 显示全部楼层
ANSYS求解框
ctrl-c interrupts ls-dyna and prompts for a sense  switch.
type the desired sense switch: sw1., sw2., etc. to continue
the execution.  ls-dyna will respond as explained in the users manual
    type                      response
   sw1.    a restart file is written and ls-dyna terminates.
   sw2.    ls-dyna responds with time and cycle numbers.
   sw3.    a restart file is written and ls-dyna continues calculations.
   sw4.    a plot state is written and ls-dyna continues calculations.
********  notice  ********  notice  ********  notice  ********
* This is the LS-DYNA Explicit Finite Element code.          *
* Neither LSTC nor the authors assume any responsibility for *
* the validity, accuracy, or applicability of any results    *
* obtained from this system. The user must verify his own    *
* results.                                                   *
* LSTC endeavors to make the LS-DYNA code as complete,       *
* accurate and easy to use as possible.                      *
* Suggestions and comments are welcomed.  Please report any  *
* errors encountered in either the documentation or results  *
* immediately to LSTC through your site focus.               *
* Copyright (C) 1990-2005                                    *
* by Livermore Software Technology Corp. (LSTC)              *
* All rights reserved                                        *
input of data is completed
initial kinetic energy = 0.43233228E+04
The LS-DYNA time step size should not exceed     0.358E-08
to avoid contact instabilities.  If the step size is
bigger then scale the penalty of the offending surface.
initialization completed
dt of cycle       1 is controlled by solid      element    2163
time...........................   0.00000E+00
time step......................   2.62724E-09
kinetic energy.................   4.32331E+03
internal energy................   1.00000E-20
spring and damper energy.......   1.00000E-20
hourglass energy ..............   0.00000E+00
system damping energy..........   0.00000E+00
sliding interface energy.......   0.00000E+00
external work..................   0.00000E+00
eroded kinetic energy..........   0.00000E+00
eroded internal energy.........   0.00000E+00
total energy...................   4.32331E+03
total energy / initial energy..   1.00000E+00
energy ratio w/o eroded energy.   1.00000E+00
global x velocity..............  -2.45116E+03
global y velocity..............   0.00000E+00
global z velocity..............   0.00000E+00
cpu time per zone cycle............      8465 nanoseconds
average cpu time per zone cycle....      8465 nanoseconds
average clock time per zone cycle..      4892 nanoseconds
estimated total cpu time          =    380628 sec (     105 hrs 43 mins)
estimated cpu time to complete    =    380627 sec (     105 hrs 43 mins)
estimated total clock time        =    220002 sec (      61 hrs  6 mins)
estimated clock time to complete  =    220002 sec (      61 hrs  6 mins)
 楼主| 发表于 2008-3-21 16:17 | 显示全部楼层
顶下
经过这几天的研究发现
其实是一样的,ANSYS直接求解也是调用的LS DYNA,但是ANSYS/LS DYNA的接触形式和单元没有LS DYNA里面多,一般的非线性分析,可以直接在ANSYS中去做
GMT+8, 2025-8-8 14:44 , Processed in 0.137343 second(s), 23 queries , Gzip On.
