查看: 841|回复: 0
[综合讨论] warning
发表于 2008-2-27 15:58 | 显示全部楼层 |阅读模式
*** WARNING ***                         CP =       3.250   TIME= 08:40:51
The program chosen initial timestep/load-factor is arbitrary.  It is
necessary for the user to supply a suitable initial
timestep/load-factor through the NSUB or DELTIM command for
convergence and overall efficiency.
哪位能告诉我一下  这个究竟是什么错误  我用的单元是link10   这个单元究竟需要怎么设置
还有上面那个CP =       3.250的cp是什么意思
谢谢
GMT+8, 2025-1-13 15:50 , Processed in 0.067866 second(s), 17 queries , Gzip On.
