查看: 5873|回复: 4
[CFD及热分析] 用ANSYS11.0模拟FSI问题所出现的错误
发表于 2008-2-20 22:45 | 显示全部楼层 |阅读模式
| ERROR #002100061 has occurred in subroutine SERVE_CLIENTS.         |
| Message:                                                           |
| The connection between this CFX process and an external process    |
| has died unexpectedly.  The following error was received:          |
|   External process  : ANSYS                                        |
|   Error experienced : Read                                         |
| ** This error is fatal:  Terminating ANSYS CFX Solver execution ** |
| Please review the output, error and log files from both the CFX    |
| and external processes to determine the cause of the error.        |
|                An error has occurred in cfx5solve:                 |
| The ANSYS CFX solver exited with return code 1.   No results file  |
| has been created.                                                  |
End of solution stage.
| The following transient and backup files written by the ANSYS CFX  |
| solver have been saved in the directory                            |
| F:\0212\0217\0220wanshang_001:                                     |
| 0_CS_full.trn                                                      |
| ANSYS Solver terminated with return code 256                       |
| The results from this run of the ANSYS solver have been written to |
| F:\0212\0217\0220wanshang_001.ansys                                |
| The following user files have been saved in the directory          |
| mon        |
This run of the ANSYS CFX Solver has finished.
描述:我模拟的是一根弯管在内部高速流体运动下所产生的振动问题。用的方法是       ANSYS11.0软件双向耦合的方法
       总是在求解过程中出现这样的错误。
       希望高人能够指点一下! 谢谢了!
       欢迎讨论!
发表于 2008-2-26 15:36 | 显示全部楼层
同样学习中
能否把命令贴上来共同研究
发表于 2011-5-25 09:52 | 显示全部楼层
变形过大,网格发生畸变所致,建议调整网格,或增加弹性模量再试
发表于 2014-10-28 19:50 | 显示全部楼层
是固体域的还是流体域网格呢?
发表于 2014-10-28 19:51 | 显示全部楼层
是固体域的还是流体域网格呢?
GMT+8, 2024-11-17 17:50 , Processed in 0.095513 second(s), 18 queries , Gzip On.
