查看: 901|回复: 0
[综合讨论] Finite Element Method (FEM) Collection
发表于 2008-1-8 22:23 | 显示全部楼层 |阅读模式
        Finite Element Method (FEM) Collection        Contains Seventy-Five selected books on finite element method.
The finite element method is a computational technique for obtainingapproximate solutions to the partial differential equations that arisein scientific and engineering applications. The advantages of thefinite element method over the finite difference method are thatgeneral boundary conditions, complex geometry, and variable materialproperties can be relatively easily handled. Finite element analysisare at present very widely used in the engineering analysis of solidsand structures and of heat transfer and fluids.
Book List
Adaptive Finite Element Methods for Differential Equations - Wolfgang Bangerth.djvu
An Introduction to Computer Simulation - Woolfson and Pert.pdf
An Introduction to Multigrid Methods - Peter Wesseling.djvu
Anisotropic Analysis Using Boundary Elements - N.A. Schclar.djvu
Applied Finite Element Analysis - Larry J. Segerlind.pdf
Basic Structured Grid Generation - M. Farrashkhalvat and J.P. Miles.pdf
Boundary Elements An Introductory Course - Brebbia and Dominguez.djvu
Boundary Methods Elements Contours and Nodes - Subrata Mukherjee.pdf
Delaunay Triangulation and Meshing - George & Borouchaki.djvu
Design of Adaptive Finite Element Software - Alfred Schmidt & Kunibert G. Siebert.pdf
Discontinuous Finite Elements in Fluid Dynamics and Heat Transfer - Ben Q. Li.pdf
Domain Decomposition Methods Algorithms and Theory - Andrea Toselli.pdf
Elsevier - Handbook of Numerical Analysis V1 Part1 - Finite Difference Methods.djvu
Elsevier - Handbook of Numerical Analysis V2 Part1 - Finite Element Methods.djvu
Elsevier - Handbook of Numerical Analysis V4 Part2 - Finite Element Methods.djvu
Elsevier - Handbook of Numerical Analysis V9 Part3 - Numerical Methods for Fluids.djvu
Engineering Analysis with ANSYS Software - Y. Nakasone and S. Yoshimoto.pdf
Error-Controlled Adaptive Finite Elements in Solid Mechanics - E. Stein.djvu
Finite Element Aanalysis - David W. Nicholson.pdf
Finite Element Analysis - Flaherty J.E.pdf
Finite Element Analysis of Composite Laminates - Ochoa and Reddy.djvu
Finite Element Analysis Theory and Applications with ANSYS - Saeed Moaveni.pdf
Finite Element Analysis with Error Estimators - J. E. Akin.pdf
Finite Element Based Fatigue Calculations - Bishop & Sherratt.pdf
Finite Element Method - Boundary Element Method - Peter Hunter.pdf
Finite Element Method - Fluid Dynamics - Zienkiewicz and Taylor.pdf
Finite Element Method - Solid Mechanics - Zienkiewicz and Taylor.pdf
Finite Element Method - The Basis - Zienkiewicz and Taylor.pdf
Finite Element Methods - Parallel-Sparse Statics and Eigen-Solutions - D.T.Nguyen.pdf
Finite Element Methods and Their Applications - Zhangxin Chen.pdf
Finite Element Methods for Flow Problems - Jean Donea & Antonio Huerta.pdf
Finite Element Modeling for Stress Analysis - Robert D. Cook.pdf
Finite Element Procedures - K.J. Bathe.djvu
Finite Element Techniques for Fluid Flow - Connor and Brebbia.pdf
Finite Elements for Nonlinear Continua & Structures - Belytschko.pdf
Finite Elements Using Maple - A Symbolic Programming Approach - Portela & Charafi.djvu
Finite Volume Methods for Hyperbolic Problems - Randall J. Leveque.pdf
Fundamentals of Finite Element Analysis - David V. Hutton.pdf
Fundamentals of the Finite Element Method for Heat and Fluid Flow - Lewis Nithiarasu.pdf
Galerkin Finite Element Methods for Parabolic Problems - Vidar Thomee.pdf
Generalized Difference Methods for Differential Equations - Li Chen Wu.djvu
Handbook of Grid Generation - Thompson, Soni and Weatherill.djvu
Higher-Order Finite Element Methods - Pavel Solin.pdf
Introduction to PDEs - A Computational Approach - Tveito & Winther.pdf
Mesh Free Methods - Moving Beyond the Finite Element Method - G.R.Liu.djvu
Mesh Generation Application to Finite Elements - P.J. Frey & P.L. George.djvu
Mixed and Hybrid Finite Element Methods - Brezzi and Fortin M.djvu
Multifield Problems in Solid and Fluid Mechanics - Rainer Helmig.pdf
Multigrid - Trottenberg et al.djvu
Nonlinear Continuum Mechanics for Finite Element Analysis - Bonet & Wood.pdf
Non-linear Finite Element Analysis of Solids and Structures Vol.1 - M.A. Crisfield.pdf
Non-linear Finite Element Analysis of Solids and Structures Vol.2 - M.A. Crisfield.pdf
Nonlinear Stability of FV Methods for Hyperbolic Conservation Laws - Francois Bouchut.pdf
Numerical Methods for Elliptic and Parabolic PDEs - P. Knabner & L. Angermann.pdf
Numerical Methods for Partial Differential Equations - W.F. Ames.djvu
Numerical PDEs for Environmental Scientists and Engineers - D.R.Lynch.pdf
Numerical Solutions of PDEs by the Finite Element Method - Johnson.djvu
Numerical Treatment of Partial Differential Equations - Grossmann and Roos.pdf
Partial Differential Equations and the Finite Element Method - P. Solin.pdf
Process Modelling and Simulation with Finite Element Methods - William B. J. Zimmerman.pdf
Programming the Finite Element Method - I. M. Smith & D. V. Griffiths.djvu
Splines and Variational Methods - P. M. Prenter.djvu
Structural Analysis with Finite Elements - Friedel Hartmann & Casimir Katz.pdf
The Boundary Element Method in Engineering - A. A. Becker.djvu
The Boundary-Domain Integral Method for Elliptic Systems - Andreas Pomp.djvu
The Combined Finite-Discrete Element Method - Ante Munjiza.pdf
The Finite Element Method - Thomas J. R. Hughes.djvu
The Finite Element Method a Practical Course - G.R. Liu & S.S. Quek.pdf
The Finite Element Method for 3D Thermomechanical Applications - Guido Dhond.pdf
The Finite Element Method for Solid and Structural Mechanics - Zienkiewicz & Taylor.pdf
The Finite Element Method in Engineering - S.S. Rao.pdf
The Finite Element Method using MATLAB - Kwon and Bang.pdf
The FV, FD, & FE Methods as Numerical Methods for Physical Field Problems - Mattiussi.pdf
The Scaled Boundary Finite Element Method - Wolf J.P.djvu
The Theory of Difference Schemes - Alexander A. Samarskii.djvu
下载地址:http://thepiratebay.org/tor/3880821/Finite_Element_Method_(FEM)_Collection
GMT+8, 2025-1-28 05:28 , Processed in 0.087029 second(s), 17 queries , Gzip On.
