查看: 1029|回复: 4
[编程技巧] 在求二次规划的时候遇到的错误提示
发表于 2007-11-28 15:14 | 显示全部楼层 |阅读模式
Warning: Large-scale method does not currently solve this problem formulation,
using medium-scale method instead.
> In quadprog at 264
  In main_svcpath at 57
Maximum number of iterations exceeded; increase options.MaxIter.
To continue solving the problem with the current solution as the
starting point, set x0 = x before calling quadprog.
请问这是啥意思?
下一步怎么做呢?
发表于 2007-11-28 15:16 | 显示全部楼层
原帖由 jytan 于 2007-11-28 15:14 发表
> In quadprog at 264
Maximum number of iterations exc ...
如果看不懂英文,用金山词霸吧,没有什么难度
 楼主| 发表于 2007-11-28 18:43 | 显示全部楼层
英文我都看懂了,还是不太理解。。
 楼主| 发表于 2007-11-28 18:44 | 显示全部楼层
就是不太明白错误在哪。。该怎么改进。
发表于 2007-11-28 18:48 | 显示全部楼层
help quadprog
GMT+8, 2024-10-2 18:34 , Processed in 0.062565 second(s), 17 queries , Gzip On.
